90 Tracker 1.6 sohc auto "Timing Belt" - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 11th, 2011, 08:23 AM   #1
choppergar
choppergar's Avatar
Default 90 Tracker 1.6 sohc auto "Timing Belt"
I'm new to these. I'm new to everything.
Put use motor in. New timing belt.
Ran great 2 tanks of gas. Third tank, running down eway 55mph, motor shut down, NO NOISE of anything hitting anything. Won't start, no compression, turns over easy. Got home took oil cap off, turned over motor, cam not moving. Must be new timing belt broke. Heard of O clearance engines, is this motor one of them things?
First step to do is pull and check timing belt & replace.
Sec rum compression check.
Any ideas what to look for?
Thanks for your time
choppergar is offline   Reply With Quote
Old October 11th, 2011, 08:36 AM   #2
cskarnes
good to go on this motor. retime everything and new belt.
cskarnes is offline   Reply With Quote
Old October 11th, 2011, 05:11 PM   #3
A4X4SPIT
A4X4SPIT's Avatar
Ive broke belts on several 1.6 & no isues sounds like you've got the right plan for the fix
A4X4SPIT is offline   Reply With Quote
Old October 12th, 2011, 07:17 AM   #4
choppergar
choppergar's Avatar
Thanks guys. Have to get yj out of garage to make room. Will keep u posted on what I fine. Thanks alot.
Page generated in 0.14912 seconds with 35 queries
