10 bolt lockers? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 9th, 2011, 10:50 AM   #1
Disturban
Disturban's Avatar
Default 10 bolt lockers?
Does anyone make a selectable locker for the Chevy 10 bolt IFS or am I looking at doing a SAS if I want a selectable locker?
Old October 9th, 2011, 12:24 PM   #2
in2deep
Hole tester
dont think the cv shafts would take it. ever if you did find one
Old October 9th, 2011, 05:36 PM   #3
Disturban
Disturban's Avatar
This is just going to be a daily driven vehicle with almost stock size tires, might need locker occasionally to get out of driveway in the winter, no rock climbing or anything like that.
I could use a lunch box locker but I am afraid it might make it steer funny on snow covered roads that's why I want a selectable locker but I don't know if they make them or not and I also don't even know what I have as far as ring gear size and spline count. I am assuming it is a 28 spline and 8.25" ring gear?
Does anyone make heavy duty CV shafts?
Old October 9th, 2011, 05:39 PM   #4
koochman450r
koochman450r's Avatar
i have an 87 chevy with the 10 bolt solid axle front and i have an ARB in mine. Dont know if they are the same or not but if they are then yes they do.
you won this battle.
Old October 9th, 2011, 05:44 PM   #5
Disturban
Disturban's Avatar
I know they make them for the solid front 10 bolt but I don't know if that would work in a IFS?
Old October 9th, 2011, 06:42 PM   #6
xjmichigan
xjmichigan's Avatar
Concrete
Old October 9th, 2011, 08:20 PM   #7
Disturban
Disturban's Avatar
Originally Posted by xjmichigan View Post
Concrete
$22,000 and I could have a concrete driveway, it is at least an 1/8 mile long and every winter and spring at least 20 to 30 people get stuck in it sometimes people with 4x4 get stuck. Spring is even worse than winter because all the snow melts and the ground is super soft with slick ass mud that just sucks the tires right down in it, might see about getting gravel poured on top before snow flies.
Old October 9th, 2011, 08:39 PM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
what vehicle is this for? to my knowledge you can only get a selectable locker for a 9.25 IFS unit found in 3/4-1 ton trucks. the 7.25 S truck and 8.25 1/2 ton models won't handle the stress associated with a locked axle. ARB makes the one for the 9.25 unit.
Old October 9th, 2011, 09:58 PM   #9
Disturban
Disturban's Avatar
Yep this is a 1/2 ton...they do make lunch box lockers for it, how do you think it would drive on snow covered roads with one of those? Also would the 3/4ton unit be a direct bolt in and could I use the 6 lug cv axles in it or does the 3/4 ton axles with the 8 lugs have more bolts or different pattern that bolts the axles to the carrier and different spline count, if so does anyone make a hybrid axle of some sort to do this kind of swap on a 1/2 ton? What about limited slip diffs, do they make any of those for the 8.25 front ifs?
Old October 11th, 2011, 08:21 AM   #10
kkodet
kkodet's Avatar
If you have vaccum engage you could weld the spider gears in the front. S-10 guys have been doing this for years. Then it only fully locks when four wheel is engaged. Kinda a redneck way to go, but it works. Plus like others said, your cv's won't like it, but may survive light use.
Old October 11th, 2011, 08:23 AM   #11
kkodet
kkodet's Avatar
BTW, lunchboxes in front are great. They don't engage until you put it in four wheel. I now have 100,000 miles on the one in my Cherokee, no issues.
Old October 12th, 2011, 07:10 AM   #12
Muttly
Muttly's Avatar
2009 & 2010 Hummer H3 Adventure had e-lockers in the front and rear. They had a different 3rd that was stronger. Don't know if it would work or if you could find one.
Muttly is offline   Reply With Quote
Page generated in 0.20532 seconds with 59 queries
