99 cummins - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 7th, 2011, 07:46 PM   #1
boggin-machine
boggin-machine's Avatar
Default 99 cummins
drive starts and runs just fine. go to shut it off and the truck stays running. once and a while it will shut off (or atleast it did a few times) a few times in neutral. now it wont shut off at all.
i also have put a new ignition switch in it with no difference. worked once and then back to the same old shit. took it out and put the old one back in. to shut the truck down i have to pop the hood and pull a fuse.
what could it be?
Old October 7th, 2011, 07:51 PM   #2
lauriat
lauriat's Avatar
Does it have a programmer on it?
lauriat is offline   Reply With Quote
Old October 7th, 2011, 07:52 PM   #3
boggin-machine
yes
been on the truck for the past 2 years ive owned it as well.
Old October 7th, 2011, 08:31 PM   #4
lauriat
lauriat's Avatar
My 01 Cummins had the same problem the day I sold it. It was shorted out somewhere between the engine fuse and the programmer. I unplugged the qaudzilla from the fuse and it worked fine. I never found out exactly what it was because the kid bought it.
Old October 14th, 2011, 02:25 PM   #5
matt440rev
the quad has a turbo timer in it, did you make sure that wasnt on?
matt440rev is offline   Reply With Quote
Old October 14th, 2011, 05:43 PM   #6
boggin-machine
figured it out. theres a sensor that the wiring goes into on the drivers side of the engine. the terminals werent gettting a good ground. took the pig tail off. cleaned up the male ends on the sensor. cut the female ends off the pig tail and put new ones on. plugged it back in and works fine for the time being.
Page generated in 0.20234 seconds with 41 queries
