90 ranger with brake issues!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 5th, 2011, 10:29 PM   #1
phillie86
Default 90 ranger with brake issues!!!
okay so heres the problem... the truck had 2 blown brake line so i by past the rear brakes and made it so it only has front brakes. replaced front brake line and bleed the master cylinder and brakes line. but i still don't have brakes. when truck isn't running its got lots of pressure behind break peddle. as soon as you start truck it goes straight to the floor??? drivers side caliper is froze up alil... could that be problem? or should i run brake line to rear again? or maybe brake booster? iv fixed other vehicles this way before and never had this... anyone have any ideas or had/seen this issue before and have an idea of what it is? i need to know by tomorrow morning cause im fixing tomorrow! someone please help!
phillie86 is offline   Reply With Quote
Old October 6th, 2011, 07:00 AM   #2
Elvis13
I'm not exactly sure how you by past? the rears but you probably trapped air in that you have not bled.
Old October 6th, 2011, 11:24 AM   #3
phillie86
by by past i mean that i plugged the outlet on master cylinder then bleed it. i think im going to try running a line to rear like i should have to began with and see what it does. if it still doesn't work then what else could it be?
Page generated in 0.25426 seconds with 32 queries
