42 36 30lbhr injectors???? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 5th, 2011, 11:18 PM   #1
masterbeatty
masterbeatty's Avatar
Default 42 36 30lbhr injectors????
I am looking for 3. its for a ford, i know the svt ones are green.
or a set of 8 36 or 30 lb injectors
Old October 14th, 2011, 11:44 PM   #2
masterbeatty
top also need a maf sensor calibrated for them
Old October 15th, 2011, 08:50 AM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
what are the yellow ones?
H.o.r.e
Old October 15th, 2011, 04:51 PM   #4
masterbeatty
19lbhr i can also use the ones that came off of 4.0 explorers i believe 96 and up and the supercoupe
Old December 10th, 2011, 05:52 PM   #5
masterbeatty
up
Old December 10th, 2011, 08:02 PM   #6
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
What are you trying to do?
Old December 10th, 2011, 08:08 PM   #7
masterbeatty
i boought an eaton m112 and have 5 of 8 injectors. i am going to put it on a 5.0 in an explorer
Old December 10th, 2011, 08:14 PM   #8
Rob the plumber
Ahh, probably need 42's for sure unless you are using an fmu.
Old December 10th, 2011, 08:20 PM   #9
masterbeatty
yea i think i might. the 38s? or 36s? might work from the tbird supercoupe
Old December 11th, 2011, 10:00 AM   #10
masterbeatty
up
Old December 12th, 2011, 07:42 PM   #11
masterbeatty
up
Old December 21st, 2011, 07:20 PM   #12
masterbeatty
up
Old December 23rd, 2011, 09:44 PM   #13
masterbeatty
anyone
Old December 24th, 2011, 11:06 AM   #14
Rob the plumber
36# injectors come in the gm supercharged 3800. You could probably find them in a bone yard easily. I got a set of 6 on Ebay for like $70
Old December 24th, 2011, 03:46 PM   #15
masterbeatty
Thanks rob
Old December 25th, 2011, 09:30 AM   #16
masterbeatty
ToP
Old December 28th, 2011, 06:41 PM   #17
masterbeatty
top
Old December 29th, 2011, 08:02 PM   #18
masterbeatty
Old January 4th, 2012, 08:50 PM   #19
masterbeatty
top
Old January 11th, 2012, 02:18 PM   #20
ttfiveohranger
Mr. Research
I have a set of low mile 42lbs from a ford 03-04 supercharged cobra.. the 4 hole ones with a nice spray pattern wanted $200.. also a 73mm c&l maf thats for a 5.0 mustang. you can buy a sample tube. not sure it will work for exploder. maybe a supercharged lightning maf
ttfiveohranger is offline   Reply With Quote
Page generated in 0.42125 seconds with 83 queries
