my 302 is throwing codes!? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 5th, 2011, 02:42 PM   #1
sluginxlt
tooweel or not tooweel
sluginxlt's Avatar
Default my 302 is throwing codes!?
On my 96 2wd 5.0 it always had light on from bad o2 sensor but always ran great. All of a sudden the other day it started to run rough at idle and also sounds like a lttle back fire if I give it a rev. I changed the o2 but its running rough still with a code of 401 and 306. An egr system problem and missfire on cyl 6. Where do I start besides throwing money at it with out knowing the cause. Thanks in advance
sluginxlt is offline   Reply With Quote
Old October 5th, 2011, 02:48 PM   #2
jaysusr
jaysusr's Avatar
Full tune upand clean the egr
Old October 5th, 2011, 02:52 PM   #3
buttercr125
I work out
buttercr125's Avatar
Sell the Ford and buy a Chevrolet.
Problem solved!!
Old October 5th, 2011, 03:24 PM   #4
buttercr125
I work out
DPFE sensor and possibly a tune up.
Old October 5th, 2011, 07:40 PM   #5
sluginxlt
sluginxlt's Avatar
i did plugs and wires a few months ago, also is it possible for exhaust leak to cause problem? it sounds like my exhaust leak got a lot worse at the same time the other problems occured, i finally got under it and it seems like the exhaust leak is from the top of the front right catalytic converter
Old October 5th, 2011, 07:44 PM   #6
masterbeatty
masterbeatty's Avatar
what plugs did you run and what wires?
Old October 5th, 2011, 07:56 PM   #7
sluginxlt
sluginxlt's Avatar
pretty sure they were motorcraft, they came new with the truck in the back seat
Old October 5th, 2011, 08:04 PM   #8
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Check for any vacuum lines that may have cracked or broken with the recent maintenance you have performed.
Old October 5th, 2011, 09:11 PM   #9
GREASYHANDS
GREASYHANDS's Avatar
Make sure the egr valve is not stuck open.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 5th, 2011, 09:13 PM   #10
GREASYHANDS
Did the exhaust leak overheat the plug or wire?
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old October 5th, 2011, 09:19 PM   #11
Ford rules
Ford rules's Avatar
Thats a coil pack motor correct? My 96 5.0 was doing the same and it ended up being the coil packs id check them.
Old October 5th, 2011, 09:22 PM   #12
sluginxlt
sluginxlt's Avatar
i was not able to get the egr valve off yet, looks like ill need a stubby 13mm ratcheting wrench. originally i thought a 302 in an explorer was a great idea... that was until i had to work on it! seems like there is no room to access anything on this pos.
Old October 5th, 2011, 09:26 PM   #13
sluginxlt
sluginxlt's Avatar
this is gonna sound dumb but how do i "check" them? i am clueless when it comes to electrical troubleshooting and thats probably why it is driving me crazy
Old October 5th, 2011, 09:47 PM   #14
Ford rules
Ford rules's Avatar
Take the EGR off and block it off that craps worthless, its like peeing in your own mouth if u think about it although then it would throw anoter code. If its not tripping a code for the egr i wouldnt bother taking it off but it dosent hurt to check.
Some one correct me if im wrong its been a while but i believe u check the resistance across the terminals i think mine was like 15 ohms... i can check em again tmrw its been like a year since i checked em.
Old October 5th, 2011, 09:49 PM   #15
sluginxlt
sluginxlt's Avatar
it does have an egr code. i have 2 codes right now, egr system, and cyl 6 missfire
Old December 2nd, 2011, 02:17 PM   #16
sluginxlt
sluginxlt's Avatar
Swapped in some junkyard parts, egr valve, the sensor on top of it, and the other round cap looking sensor. I also took off the end intake peice that the throttle body and egr mount to so I could clean it all out and still runs the same with the engine light on. I unplugged the battery to reset it but after about 5 minutes driving it wad right back on
Page generated in 0.32474 seconds with 71 queries
