2005 6.0 Diesel no power - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 4th, 2011, 07:36 PM   #1
Wheelman
Extreme Mudder
Wheelman's Avatar
Default 2005 6.0 Diesel no power
I have a 2005 f-350 with a 6.0 all stock. Last weekend i was headed up north with a empty trailer. When i came off a red light the truck would barely move. Would not get more then 1000 rpm and no boost. I put it to the floor and it spit and shuddered just pouring out gray and black smoke that smelled like raw fuel. All of a sudden it took back off and ran fine. It keeps doing it intermittently when you let it coast or come to a stop.
Any help would be greatly appreciative.
Wheelman is offline   Reply With Quote
Old October 4th, 2011, 07:55 PM   #2
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Take it in and have it scanned. There is a sensor that goes bad on them, cant remember what it is called.
Old October 4th, 2011, 07:59 PM   #3
hamsmotorsports
hamsmotorsports's Avatar
Exhaust back pressure sensor could be plugged up. Also the egr valve might be full of carbon hanging up. Best to have it scanned first as it may direct you right to the problem.
hamsmotorsports is offline   Reply With Quote
Old October 4th, 2011, 08:03 PM   #4
Wheelman
Extreme Mudder
Wheelman's Avatar
Thanks i will take it in this week.
I was reading online that 04-05 and newer got rid of the ebp sensor?
i dont know if that is true or not.
Old October 4th, 2011, 08:04 PM   #5
cvwindows
I think I can make it!!!!
cvwindows's Avatar
I say it's injectors
cvwindows is offline   Reply With Quote
Old October 4th, 2011, 08:06 PM   #6
kickstand
circling the drain
kickstand's Avatar
hold on tight
Old October 4th, 2011, 08:11 PM   #7
natureboynate47
natureboynate47's Avatar
that is not correct. EBP sensor is used as input to control fuel and boost. Suburban Ford is just down the road from white lake. I'm sure there's someone there who could take a look at it for you.
natureboynate47 is offline   Reply With Quote
Old October 4th, 2011, 08:11 PM   #8
tlamphere
Mr. Jeep
tlamphere's Avatar
we had the same thing going on in a 03 clean he egr. works very well
tlamphere is offline   Reply With Quote
Old October 4th, 2011, 08:13 PM   #9
Wheelman
Extreme Mudder
Wheelman's Avatar
ya its been to Suburban Ford a few times for not wanting to start. I love the truck when it starts and runs right.
Old October 4th, 2011, 08:31 PM   #10
natureboynate47
It was kind of a joke. I work on diesels up there.
Old October 4th, 2011, 08:34 PM   #11
Wheelman
Extreme Mudder
Wheelman's Avatar
Then they do great work!! Honestly I cant complain about them they have always done good work for me.
Old October 4th, 2011, 08:40 PM   #12
natureboynate47
Thanks! Let me know if your bringing it in, I'll make sure to take care of it!
Old October 4th, 2011, 08:58 PM   #13
mattt8430
Egr valves sticking are very common
mattt8430 is offline   Reply With Quote
Old October 5th, 2011, 09:04 AM   #14
Elvis13
There is a rubber hose that comes off the passenger side of the intake that goes the map sensor. If its cut, clogged or reading incorrectly it will not read boost properly and also loose boost faster than you can make it.
The EBP is on the other side, it should be at about 17.5 idling.
You also have a VGT, if you DD your truck or idle too much, you may wear in a groove into your vanes adjustment. This may make your turbo vanes stick open and build no boost.
Old October 5th, 2011, 09:53 AM   #15
Elvis13
If it runs fine now you can bring it over. I can check your VGT, EBP, Boost pressure, EGR system and many other things in less than a minute.
Old October 5th, 2011, 10:03 AM   #16
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Ah yes... the joys of owning a 6.0. Sure do miss mine.
Old October 5th, 2011, 12:03 PM   #17
Wheelman
Extreme Mudder
Wheelman's Avatar
i took the egr out this morning it was stuck open. I cleaned it but haven't got a chance to test drive it. Thanks for all the help.
Elvis13 i might take you up on this latter this week.
Old October 5th, 2011, 12:17 PM   #18
Ridin Dirty
EGR Delete
Old October 5th, 2011, 12:40 PM   #19
Wheelman
Extreme Mudder
Wheelman's Avatar
Originally Posted by Ridin Dirty View Post
EGR Delete
Ya thats next when i get some time.
Page generated in 0.34275 seconds with 80 queries
