cherokee.....need name ideas - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 29th, 2012, 12:23 AM   #21
dfm_13
dfm_13's Avatar
alright well not a big update but i finally found time to do a little bit on the jeep.
got the driver side all folded up
and mounted the armor up, then trimmed the fender that was hanging below. tomorrow i am gonna to the other side then finish welding the wheel wells back together.
dfm_13 is offline   Reply With Quote
Old January 29th, 2012, 08:16 AM   #22
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
looks good
bbrancheau is offline   Reply With Quote
Old January 29th, 2012, 06:48 PM   #23
dfm_13
dfm_13's Avatar
today i got the other side cut and mounted up
what should my shackle angle look like? Im not positive what is considered correct or good, and help guys?
i also did a little figuring with the new cross bar, drop kit
i will need to lengthen my lower lca's, what is the best way to do this i was gonna cut it in the middle and then bevel the edges, weld it, then sleeve the whole arm. then i will need to shorten my uppers a little bit, will this limit my flex? and then also can i just eliminate one upper control arm?
Old January 29th, 2012, 06:49 PM   #24
dfm_13
dfm_13's Avatar
here is a pic of the drop kit, the middle hole there slides into the lca pocket and is bolted on, the bottom most hole is where the lca will now bolt to and the upper hole is where the upper will now bolt to
Old January 30th, 2012, 11:34 PM   #25
dfm_13
dfm_13's Avatar
today i finished welding up the stiffeners, and then attached the control arm drops and the new cross member.
here is what the new angle will be on the lca's, it is much much better
i hate removing the undercoating, by the time i was done my face was blacker than this and all you could see what the outline form my safety glasses
tomorrow i am going to make my new longer lca's and shorten my uppers. i may start on a axle truss idk yet though we will see how long the front suspension takes.
Old January 31st, 2012, 07:23 PM   #26
dfm_13
dfm_13's Avatar
i didn't get to the front suspension because the steel yard didn't have what i needed, but today i removed the inner fender on the other side and then mounted my fuel cell, i also figured our how to mount my new fuel pump. is there anyway to hook up a fuel gauge to the cell? the floor cut isn't quite done but you get the idea.
Old January 31st, 2012, 07:38 PM   #27
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Why is the floor cut/tapered like that? Curious.
Craig
Old January 31st, 2012, 07:40 PM   #28
jbsjunk
Little Member
jbsjunk's Avatar
Craig
The sump on the fuel cell.
Old January 31st, 2012, 07:42 PM   #29
dfm_13
dfm_13's Avatar
its for the pic up for the fuel cell, the bottom of the cell is not flat it tappers down.
Old February 1st, 2012, 08:33 PM   #30
drew91xj
drew91xj's Avatar
your shackle angle should be opposite of what it is now, angled to the back instead of the front.
Old February 1st, 2012, 11:40 PM   #31
dfm_13
dfm_13's Avatar
thanks, that's what i thought but wasn't sure, i am going to make some relocation brackets tomorrow or the next day.
Old February 2nd, 2012, 06:45 AM   #32
kmanxj5011
kmanxj5011's Avatar
You planning on cutting the rear qp more? Looks a little weird like that and like your tire is going to hit easily.
I am interested to see how the leaf flip works for you.
Also look into HD offroad engineering shackle boxes, They will helo that shackle angle ALOT!!!
kmanxj5011 is offline   Reply With Quote
Old February 2nd, 2012, 01:48 PM   #33
dfm_13
dfm_13's Avatar
i flipped my leafs back as do not have enough to lengthen my drive shaft right now, and no i am not done trimming yet, i am making tube fenders for it. The boxs i am making are a copy of hd offroads. Have any of you guys relocated your battery? if so what did you do about that temperature sensor in the bottom of the factory tray, doesn't that control how the battery charges?
Old February 2nd, 2012, 02:44 PM   #34
kmanxj5011
kmanxj5011's Avatar
Would dig seeing pics of the boxes you build.
What brand Drop brackets are those?
This reminds me of my 01 i built, only better.
Old February 2nd, 2012, 11:55 PM   #35
dfm_13
dfm_13's Avatar
they are skyjacker
Old February 4th, 2012, 12:18 AM   #36
dfm_13
dfm_13's Avatar
today, i got the front suspension all done, i had to lengthen my lcas, but its all done. it should flex alot better now. i also got the other side inner fender made up and welded on. Then i made mounts for the new fuel pump and filter. fired it up for the first time and it ran great off of the fuel cell. tomorrow i am going to tie up a few loose ends and maybe take a few poser flex shots in the yard.
Old February 5th, 2012, 08:13 PM   #37
dfm_13
dfm_13's Avatar
Alright well today i made my shackle relocation brackets, i pretty much copied hd offroad ones but here is some pics, they are made of all 1/4" and 3/16th"
Old February 6th, 2012, 09:48 PM   #38
dfm_13
dfm_13's Avatar
today, i got the new exhaust on and got the battery all hooked up in the back, also mounted the batter box, didn't get a whole lot done today nothing seemed to go my way, just on of those days i guess.
Old February 12th, 2012, 07:33 PM   #39
tyler5904
growing xj
tyler5904's Avatar
Good Lookin build
tyler5904 is offline   Reply With Quote
Old February 20th, 2012, 10:51 PM   #40
dfm_13
dfm_13's Avatar
alright well the past few days, i welded up the rear fenders and tied up some lose ends. painted the new front wheel wells, mounted some under hood components and got most of by oba set up in. i still need to wire the pressure switch and a few other small things like paint the panel i made to hold the gauges but it seems to work pretty well, at airs up my tires in about a minute and a half so its not too bad. i also need to set up a oilier for the intake on the compressor.
Page generated in 0.61491 seconds with 84 queries
