95 S10 Bogger Turn Key - VERY BUILT - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 4th, 2011, 09:11 AM   #1
bmx0964
bmx0964's Avatar
Default 95 S10 Bogger Turn Key - VERY BUILT
95 Chevy S10 Bogger on 78 K20 Frame.
Engine (has 4 or 5 bogs on it since being built, maybe 10 hours of run time):
383 Stroker approx 450-500hp
350 4-Bolt main block
Eagle Crank 3.75" Stroke
Eagle Rods 5.7"
Keith Black Pistons
Dart Heads 2.05" Intake 1.60" Exhaust
Edlebrock Intake
Edlebrock Carb
Upright Headers with Rain Caps/Flappers (Not in Pics but currently installed on truck)
Accell HEI Distributor
Accell Plug Wires
Accell Plugs
Aftermarket Aluminum Radiator (I think its a Griffin but I cant remember for sure)
Dual Electric Fans
Holds 60psi of oil pressure at idle. Up to 100psi when running it hard. Always had full-synthetic oil (4 or 5 oil changes already!)
Trans/Transfer Case:
TH-350
Shift Kit
203 T-Case
Axles/Tires:
Dana 60 Front 4.10 gears
14 Bolt Rear 4.10 gears
39.5x18x15 Super Swamper Boggers (Almost Brand New)
Miscellaneous:
Autometer Monster Tach w/ Shift Light
Water temp, Oil Pressure, and Voltage Gauges mounter where factory gauges were.
Tonneau Cover
The S10 body is 100% perfect ZERO rust with fresh bright yellow paint.
10,000 OBO Trailer comes with it.
Call or txt 810.869.5903 with any questions. I work Monday-Friday until 5p so leave a message and I will get back with you or txt me.
ID:	84153   Click image for larger version
ID:	84154   Click image for larger version
ID:	84155   Click image for larger version
bmx0964 is offline   Reply With Quote
Old October 8th, 2011, 06:44 PM   #2
bmx0964
bmx0964's Avatar
Bump
Old October 12th, 2011, 08:47 AM   #3
bmx0964
bmx0964's Avatar
Bump will consider trades (or partial trades) for a ranger/s10 or 3/4 ton/1 ton.
Old October 13th, 2011, 12:10 PM   #4
bmx0964
bmx0964's Avatar
ttt
Old October 17th, 2011, 10:42 AM   #5
bmx0964
bmx0964's Avatar
bump
Old October 17th, 2011, 10:50 AM   #6
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Nice looking truck I drive by it daily
H.o.r.e
Old October 18th, 2011, 11:00 AM   #7
bmx0964
bmx0964's Avatar
thanks! and bump again
Will consider all trades of equal or close to the same value. Not saying ill take anything but ya never know.
Old October 19th, 2011, 09:22 AM   #8
bmx0964
bmx0964's Avatar
ttt
Old October 20th, 2011, 07:33 AM   #9
bmx0964
bmx0964's Avatar
bump
Old October 21st, 2011, 01:57 PM   #10
bmx0964
bmx0964's Avatar
ttt for the weekend!
Old October 24th, 2011, 08:16 AM   #11
bmx0964
bmx0964's Avatar
bump
Old October 26th, 2011, 10:32 AM   #12
bmx0964
bmx0964's Avatar
bump
Old October 27th, 2011, 01:33 PM   #13
bmx0964
bmx0964's Avatar
bump
Old October 28th, 2011, 01:27 PM   #14
bmx0964
bmx0964's Avatar
bump make an offer!!!
Old February 11th, 2012, 07:55 PM   #15
thunderace31
Owner SuperbDecals.com
thunderace31's Avatar
Do the Lights and Signals work?? Out here we can cruise these around and not get mucked with :)
thunderace31 is offline   Reply With Quote
Old February 13th, 2012, 04:44 AM   #16
bmx0964
bmx0964's Avatar
If they get plugged in and new bulbs they will work fine. All of the factory wiring is there as of now but it will be getting stripped pretty soon for a new harness/switch panel. Also the motor is out right now and torn apart for upgrades... I forgot about this thread, probably should have taken it down when the motor came out... oh well haha
Page generated in 0.35535 seconds with 72 queries
