01' 7.3 runs rough. HELP - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 30th, 2011, 06:26 PM   #1
Bronc j-8
49726
Bronc j-8's Avatar
Default 01' 7.3 runs rough. HELP
I have a 2001 7.3 with 180,000 on it. My wife drove it to work with no problems and I started it up to jump start the jeep and it ran fine. Unhooked the cables, got back in the truck and it was running like shit. It only had an 1/8 of a tank of fuel, so I thought it picked something up off the bottom of the tank. So I changed the fuel filter,no change. Dropped the tank to check the screen,no change. Unhooked lift pump and I am getting good flow. Fuel bowl had lots of sediment in the bottom,so I clean that out,no change. Very hard to start if it has sat overnight. If I do drive it, it inhales fuel at an alarming rate. It does not have a SES light on. Any help would be great.
Bronc j-8 is offline   Reply With Quote
Old September 30th, 2011, 06:31 PM   #2
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
Check the codes. if it has a p1316 code, Then this http://www.ford-trucks.com/forums/80...ck-shakes.html
Just did mine two days ago. $15 plastic parts from ford, and about 1.5hrs of work.
samurai2240 is offline   Reply With Quote
Old September 30th, 2011, 06:38 PM   #3
Bronc j-8
49726
Bronc j-8's Avatar
Thanks, I will check that but last time mine came loose I had a "service engine soon" light. This time I do not. Like I said, I will check that. Thanks for the input.
Page generated in 0.22583 seconds with 32 queries
