e4od trans - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 23rd, 2006, 07:13 PM   #1
72cj304
72cj304's Avatar
Default e4od trans
put 95 motor and trans in 93 f150 in drive trans feels like it is sliping if I put it in first it goes but does not seem to shift if I manualy shift it when I put it in rev it shifts very hard and goes fine if I try to turn off od the light on the shifter will not come on it is like I am starting of in 3rd all the plugs on the trans looked to be the same on both trucks trans fluid is full and new when the trans was in the 95 it shifted fine thanks for any input
72cj304 is offline   Reply With Quote
Old September 26th, 2006, 10:40 PM   #2
thatguy
they are not the same.if you get lucky the 95 comp. will plug in and take care of the problem.if you didnt smoke the trans .
thatguy is offline   Reply With Quote
Old September 28th, 2006, 09:53 PM   #3
72cj304
72cj304's Avatar
thanks Iput the 93 trans back in last nightso should be good thanks for the input so much for an easy motor swap
Page generated in 0.23546 seconds with 32 queries
