cj7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 28th, 2011, 05:14 PM   #1
reptile610
reptile610's Avatar
Send a message via AIM to reptile610 Send a message via MSN to reptile610 Send a message via Yahoo to reptile610
Default cj7
i have an 82 cj7 with narrow track axles (think it's actually just an 82 tub) but anyways. it has 4 wheel drum brakes and dana 30 front, amc 20 rear. im told the rear end is very weak and i don't want 4 drums. what axles will fit under mine? i don't really wanna custom any axles (shorten them) unless i find a good deal on them. i plan on running 35" tires so any suggestions for axles?
reptile610 is offline   Reply With Quote
Old September 28th, 2011, 05:32 PM   #2
Wramblerguy
Wramblerguy's Avatar
your rear end isnt "very weak" the ring gear on a 20 is bigger and thicker then on a dana 44 the only weak part of the 20 is the 2 piece axles
you just need a donor later moderl dana 30 front that has disc brakes to do the swap on
i hapen to have a 30 front that has disc brakes and junk gears that would be perfect for that
Old September 28th, 2011, 05:36 PM   #3
reptile610
reptile610's Avatar
so keep the amc 20 but make it the one piece? and how much do u want for the 30? is it from a cj?
Old September 28th, 2011, 05:48 PM   #4
Wramblerguy
yes buy a set of one piece axles for your 20
and yes its out of a cj and just so you understand the gears and everything in the dif is junk, someone ran it with no lube so only the disc brake parts are good on it and the axle shafts
but 100.00 bucks for the d30
and it has 6 bolt hubs
Old September 28th, 2011, 05:50 PM   #5
reptile610
reptile610's Avatar
and all i need to do is buy a set of whatever gears i want and i should b fine right?
Old September 28th, 2011, 05:52 PM   #6
Wramblerguy
I know a guy that's got a set of one piece axles for a narrow track 20 as well
Old September 28th, 2011, 05:53 PM   #7
Wramblerguy
Yes then all you would need is gears
Old September 28th, 2011, 05:55 PM   #8
reptile610
reptile610's Avatar
hm... tempting..... i'll get back to you on these. how much would he want for the one piece?
Old September 28th, 2011, 05:59 PM   #9
Wramblerguy
T&L81CJ5 is his name on here you would have to ask him how much he wanted for his axles
And ok feel free to shoot me a pm
Old September 28th, 2011, 06:24 PM   #10
ROVER86CJ
ROVER86CJ's Avatar
I run 35 KM2's Mod 20 with a truss. disc brakes. 4:88gears. detroit locker 1pc axles
30 front 6bolt warn hubs cromolly axles yukon universals.detroit. t5 tranny d300 tcase 258 I6. tara low with a twin stick 4"BDS. double cardan rear drive 8degree shim on rear.I love it but it drives like a dream --and off road nice on the rocks. I would do it all again.
ROVER86CJ is offline   Reply With Quote
Old September 29th, 2011, 11:52 AM   #11
You don't need to do gears. Take his Dana 30 and take the complete outer knuckles and swap them over to the drum brake axle. I've done the same to convert from drum to disc.
Old September 30th, 2011, 04:04 PM   #12
reptile610
reptile610's Avatar
i was thinking about that later. saving up right now =]
Old October 2nd, 2011, 12:16 AM   #13
Wramblerguy
Agreed you probably have 354 gears or soothing decent anyway
Old October 3rd, 2011, 06:58 AM   #14
T&L81CJ5
T&L81CJ5's Avatar
Yes I have a new pair of moser engineering one piece axles that have about 40 miles on them.
http://www.moserengineering.com/axle...76-81-cj7.html
blew the pinion bearings and gears out of the 20 so the axle is being replaced. I cut the old housing up last night to get the spacers out of the old axle so they could go as a full set. Going to put them up for sale on here today, you get first crack. Already have the backing plates pressed, on all you need to do is drive in the spacer that I cut out yesterday, throw the brakes on, bleed the brakes and attach tires and drive away.
$200.00
T&L81CJ5 is offline   Reply With Quote
Page generated in 0.39846 seconds with 65 queries
