traction bars - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 12th, 2005, 08:39 PM   #1
sonic
sonic's Avatar
Default traction bars
Anyone ever make a set of traction bars or find a kit? I tried and they lasted about half their first day up at the mounds. What I really need is a set of plans and a good chep place to buy some good hiem joints. Any of you running a long arm kit in the front? Always wondered what a diffrence that made. Little weirded out about notching the body mount.
sonic is offline   Reply With Quote
Old December 12th, 2005, 09:21 PM   #2
4x4inAllDay
Dodge Father-Ram Daughter
4x4inAllDay's Avatar
Send a message via AIM to 4x4inAllDay
what happened to them?
i've seen fabtech makes a kit..
and umm why do u have to notch the body mount?.. for long arms?
4x4inAllDay is offline   Reply With Quote
Old December 12th, 2005, 10:45 PM   #3
sonic
sonic's Avatar
The Cepek long arm kit requires that you notch out the body mount below the front doors to allow for the upper arm to travel heres kind of a bad pic to show how they mount. You have to cut the old upper controle arm mount off ass well.
http://dodgetruckworld.tenmagazines....140687-album-1
Old December 12th, 2005, 10:48 PM   #4
sonic
sonic's Avatar
let me know if that link doesn't work. it may not. I'll keep looking for a better pic
Old December 13th, 2005, 08:27 PM   #5
Stan
I got a gold chain
Stan's Avatar
You can check out TDR.
Guy named Rob Thomas (Michigan Performance Diesel) makes them.
I've had them on my truck for a couple years, work great.
Stan is offline   Reply With Quote
Old December 14th, 2005, 08:44 PM   #6
sonic
sonic's Avatar
How would I go about checking them out? Do they have a web site or something. I was kinda hoping to build my own to save some cash but if the price is right I could start saving I guess...
Old December 14th, 2005, 08:48 PM   #7
Stan
I got a gold chain
Stan's Avatar
I can take some pic's for you.
Send me a PM if I forget. I tend to do that alot.
Old December 14th, 2005, 08:56 PM   #8
sonic
sonic's Avatar
Thumbs up
oh thanks man. that woud be great if you've got the time.
Mark
Old December 14th, 2005, 10:43 PM   #9
sonic
sonic's Avatar
heres a link for the actual kit:http://texastrucktoys.com/catalog/pr...roducts_id=851
Old April 4th, 2006, 06:01 PM   #10
Screaminhillbilly
Scott
Screaminhillbilly's Avatar
I have a set on my 97 ram 2500. By far one of the best investments. I bought them from Diesel Darryl. Phone#(810)853-1060. I priced out the materials and joints myself and it would have been more expensive to make them myself. Furthermore, Darryl is located in Linden MI which is right next door to you.
Hope that helps.
Scott
Screaminhillbilly is offline   Reply With Quote
Old April 4th, 2006, 11:49 PM   #11
PavementPounder
PavementPounder's Avatar
I don't think you had to do that with mine (Skyjacker) - would have to take a closer look. I think the only cutting that had to be done was around the arm mounting point on the axle to make room for the big joint and so you could tighten the nut.
You could drive over here and look at it sometime this weekend if you want.
Old April 5th, 2006, 01:10 AM   #12
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
http://www.google.com/search?hl=en&q...=Google+Search
Old April 6th, 2006, 07:16 PM   #13
sonic
sonic's Avatar
I may take you up on that offer some time. You are almost next door. Thanks everyone else for the help. I forgot I posted this thread honestly. So busy...
Mark
Old April 6th, 2006, 07:18 PM   #14
PavementPounder
I got the remaining fluids changed ont he truck and drove by your work a couple times today. You're at that Jeep Dealer on M-59, right? Are you a Tech? I have a noise from the rear of the Ram and I want to figure out if its the driveshaft carrier bearing, so I need to put it up on a lift, put it in drive, and listen. Think you can hook me up with a little inspection?
Old April 7th, 2006, 05:01 PM   #15
sonic
sonic's Avatar
I might be able to do that on a saterday afternoon. The owner has been getting kinda testy about us pulling in cars that aren't customers. You should check the u-joints while its on the ground since its lifted. I found that out the hard way with mine and my drive shaft issue. Well see what we can work out though.
Old April 8th, 2006, 09:25 PM   #16
PavementPounder
Well, I can buy some shit there to technically be a customer. I need key fobs and a couple other things for my XJ... :tonka:
Old April 8th, 2006, 11:10 PM   #17
sonic
sonic's Avatar
Give me a call sometime man. We'll work sumthin out.
Page generated in 0.39069 seconds with 74 queries
