Link Bushings - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 26th, 2011, 10:45 AM   #1
jeepxj2007
Send a message via AIM to jeepxj2007
Default Link Bushings
I am building a F150 truggy. The front suspension is going to be a radius arm set up out of 2x.250 D.O.M. with ballistic radius arm mounts and the rear is a triangulated 4 link. At the axle end of all the links I am going to run poly bushings. I found a pretty decent price on some poly bushings and have heard good things about this company. Do you think these would work, only reason I ask is because out of all the setups I seen it always seems like people use a larger diameter bushing, but compared to the poly performance control arm bushings the outer d.o.m. sleeve on these bushings are thicker. They are still available in 2.625 or 3.00 wide and with a 9/16" inner sleeve, just the outer diameter isn't as large, it is only 2" versus 2.625 and some larger ones. Would I be okay using these?
http://www.barnes4wd.com/product_inf...oducts_id=2360
jeepxj2007 is offline   Reply With Quote
Page generated in 0.13800 seconds with 26 queries
