Street Car, TH350 vs 700R4 - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 26th, 2011, 03:24 PM   #21
skife
skife's Avatar
if its not going to be driven all the time, th350 is fine.
Old September 26th, 2011, 05:44 PM   #22
Disturban
Disturban's Avatar
From what I've seen, on the strip, the 700R4 cars don't have any advanatage from the low gearing, and are usually a little slower due to higher parasitic loss.
Another thing that was not mentioned is if this is going to be mostly a drag car or stop light warrior because you cannot get a transbrake for a 700r4 but you can for the th350, so if that was the case I would go with the th350, if it is something that you plan on cruising freeways or taking on any kind of trips or daily drive it I would go with the 700r4 just for the overdrive.
Old September 26th, 2011, 07:01 PM   #23
Mainly 0 to 65mph street use (cruise, drive to work, etc)
It will be 90% non freeway use(cruise nights and my 10 mile drive to work occasionally), 5% strip, 5% dunes. Talking a 60's Jeep here, not a daily driver.
I don't have a problem with the RPMs with 4.10s and TH350. I used to drive my Deuce to work, the 7.8 liter straight piped diesel @ 2600rpm (redline), I drove that many times, including 200 miles straight.
I am thinking, with street tires, the full time AWD probably works better than running some 31x15" ET streets on the rear in 2WD.
Old September 28th, 2011, 06:34 PM   #24
I think i'm going to use the parts I have, which is a 700R4, and Dana 44 front/9" rear, with 4.56 gears. The axes are not as heavy as I had thought, 220lbs front, 210 rear, complete. That includes drag link, tie rod, and track bar.
Should launch like a beast. I think I'll run 30" tires (general UHPs that I can get dirt cheap).
Old September 28th, 2011, 06:41 PM   #25
madscience
Ballsohardthatshitcray
madscience's Avatar
i have a built 700r4 behind the big block in my little hot rod caprice, i frickin love it! a 3.06 first gear AND overdrive? 700r4 ftw.
madscience is offline   Reply With Quote
Old September 29th, 2011, 06:54 AM   #26
AFRd_CJ5
AFRd_CJ5's Avatar
I run 30" MT ET Streets on my Jeep with a th350 and 4.88 gears. No highway driving/etc. It's fine for what I do.
I am not a fan of the 700's at all, but this is not my project. I can say though, there is no possible way I would ever want to run 4wd on the street. Sooo much power loss through that drivetrain, it's not even funny.
As far as converters go though, a GOOD converter is going to be expensive with either trans, so don't let that price bother you.
AFRd_CJ5 is offline   Reply With Quote
Page generated in 0.23842 seconds with 41 queries
