04 1500 z71 g80 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2011, 05:51 PM   #1
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Default 04 1500 z71 g80
2004 Silverado 1500
Crew Cab
Z71 Pkg
Changed out rear diff fluids. Since this has the Z71 off road package which includes the G80 mechanical locking differential, does this require LSD additive? I am saying no, because it is mechanical and not clutches like a Ford LSD. Discuss.
Old September 24th, 2011, 07:17 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
it does have clutches inside the case. LSD additive is a good idea to put in.
Old September 25th, 2011, 07:35 AM   #3
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
IIRC, it's not necessary for an additive. Unlike the clutches in a "regular" LSD that get work every time you turn a corner - the clutches in a GovLock only engage once there is a 100 rpm difference between wheels.
@clarkstoncracker
Old September 25th, 2011, 10:28 AM   #4
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Just put 75w140 in it and be done!!! It's not that much more than regular gear fluid!!
Old September 25th, 2011, 05:01 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
this is true but without a friction modifier the clutches will not engage with enough force to cause wheel lock up. instead they will slip and eventually burn up.
Old September 25th, 2011, 05:08 PM   #6
HVYRTFT
Reed my teef
HVYRTFT's Avatar
I thought the gov lock was mechanical and not clutches.
Old September 25th, 2011, 08:45 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
watch and learn
Page generated in 0.25620 seconds with 45 queries
