Long-term storage for used auto trans - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 22nd, 2011, 10:42 AM   #1
phittie1100
phittie1100's Avatar
Default Long-term storage for used auto trans
The feedback from the transmission shop is that my auto trans is failing, but still functional. I am picking up a used trans to replace it this week, but plan to continue to drive on the current one until it is good and dead. Any suggestions for storing the used one I am picking up? Anything I need to do to protect it for a week, month or year? I have a dry, heated garage to store it until I need it.
Paul - 2005 Wrangler Unlimited
KD8PAV
phittie1100 is offline   Reply With Quote
Old September 24th, 2011, 04:34 AM   #2
cerial
Direct Drive FTW
cerial's Avatar
Seriously how long are you going to wait? What is the trans doing? Have you checked the codes on it?
If you know it is going out set aside a weekend, rent/borrow the cherry picker/ trans jack, and swap the newer one in. Unless it is something very minor you may get a month or 2 out of it before it looses a gear or the hard shifting starts causing stuff to move around inside the jeep.
For a month or 2 you should be fine. Just keep Dirt/ moister out of it and maybe turn it every now and then. I would replace the seals why you have it out before putting it in. Use the old converter or pour fresh fluid in the new one. Run it for 1 week(with it filled to the proper level) making sure everything works then replace the filter and fluid to get out any moister.
Old September 24th, 2011, 04:34 AM   #3
cerial
Direct Drive FTW
cerial's Avatar
Old September 24th, 2011, 06:24 AM   #4
What vehicle Paul?
Old October 3rd, 2011, 12:01 PM   #5
phittie1100
This is for my DD 2004 Wrangler (42RLE). The electric solenoid for the lockup feature of the torque converter has failed (P0740) so it is turning a few extra R's at highway speed. Trans shop dropped the pan to make sure it wasn't anything catastrophic, fluid was still good, nothing else noted on the visual inspection. No other symptoms yet. I've previously installed a temp gauge and HD cooler for towing, so I'll be able to keep an eye on it - I have a trip planned in a couple of weeks so we'll see how it does on the freeway with the camper. I need to start shopping for a replacement trans, but have no plans to swap it out until this one starts acting like it is done, have a couple of feelers out to local junkyards in case something shows up wrecked. Just need to know how long it can sit on the shelf without doing anything special to it.
KD8PAV
Old October 3rd, 2011, 12:10 PM   #6
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Heck- I'd just stick a new TCC in there and call it a day. They are cheap and easy to instal. You don't even need to remove the valve body to get at it.
Old October 3rd, 2011, 12:14 PM   #7
Toivo
Feel lucky?
Toivo's Avatar
this.
unless the trans is fragged, just fix what is broken.
Old October 3rd, 2011, 03:24 PM   #8
phittie1100
Other than how to kill one in deep water, I don't know jack about auto transmissions - not sure why the trans shop I took it to didn't suggest that, you would think they would want to make a couple of bucks?
KD8PAV
Old October 3rd, 2011, 06:45 PM   #9
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
It sounds like they were hoping to make a bunch of bucks replacing the trans rather that just a couple of bucks just replacing a part.
Old October 3rd, 2011, 06:55 PM   #10
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Replace the trans now before it is trashed and you can't rebuild it. Take your time and rebuild it for when your new one takes a crap.
Old October 3rd, 2011, 06:59 PM   #11
I would talk to Tranny Tom. He's done right by me.
Old October 4th, 2011, 09:48 AM   #12
skife
skife's Avatar
advice on longterm storage of an auto trans.... buy a bag of oil dry or some pig mat...
Page generated in 0.23861 seconds with 59 queries
