*found*explorer 2" lift - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 21st, 2011, 12:36 PM   #1
big_ol_bronco78
Psalm 40:2
big_ol_bronco78's Avatar
Default *found*explorer 2" lift
Looking for 2" lift for front of my 91 explorer, just coils and ttb brackets. thanks
big_ol_bronco78 is offline
Old September 23rd, 2011, 08:41 AM   #2
big_ol_bronco78
Psalm 40:2
Bump
Old September 23rd, 2011, 08:45 AM   #3
alboy79
Where's your loyalty lie?
alboy79's Avatar
You don't need brackets for a 2" lift. Just coils. Ordered new to my door were less than 100$.
alboy79 is offline
Old September 23rd, 2011, 11:03 AM   #4
big_ol_bronco78
Psalm 40:2
Thanks, thought i needed brackets with 2" and over like the fullsize TTB's.
Old September 23rd, 2011, 11:45 AM   #5
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
You can also f150 2wd lower coil mounts from the junkyard For about 1" or 2".
http://therangerstation.com/tech_lib...toryspacer.htm
osteologation is offline
Old September 23rd, 2011, 11:55 AM   #6
big_ol_bronco78
Psalm 40:2
Thanks, i'll keep that in mind. i'd like to upgrade coils, but might do that to go from 2"-4" lift later on.
Old September 23rd, 2011, 11:59 AM   #7
84mudder
84mudder's Avatar
Send a message via AIM to 84mudder
you may need camber/castor bushings to get the tires straight.
84mudder is offline
Old September 23rd, 2011, 12:00 PM   #8
osteologation
You can only go about 2" before you can't align it. Then you will need drop brackets.
Old September 23rd, 2011, 12:11 PM   #9
@_'-'
You can go to 3" before you need drop brackets. I would buy the coil spacers on ebay. http://cgi.ebay.com/ebaymotors/Ford-...item2c5e1c58d0 I have done this to my 96 and my dads 95 rangers. The camber bushings can be bought here https://napaonline.com/Catalog/Resul...+50028+2028044
here are some pics of the install
before
After
process
@_'-' is offline
Old September 23rd, 2011, 01:04 PM   #10
big_ol_bronco78
Psalm 40:2
Thanks, i'll keep the spacer's in mind if i can't find coils.
Old September 25th, 2011, 04:23 PM   #11
big_ol_bronco78
Psalm 40:2
Bump
Old September 28th, 2011, 01:32 PM   #12
big_ol_bronco78
Psalm 40:2
Found
Page generated in 0.25456 seconds with 59 queries
