AntiRock Swaybar---SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 20th, 2011, 04:04 PM   #1
bbaXJ
Yooper In Training
bbaXJ's Avatar
Default AntiRock Swaybar---SOLD
It's actually a Rock Equipment brand rather than Currie, but people know the AntiRock name much better so that's what I'm calling it. Exact same design and function as the AntiRock, just a different manufacturer and includes aluminum arms, which are an additional cost in the Currie kit. It's used but in very good condition, ready to be bolted on and run. It's dirty in the pics from sitting around, but could be cleaned up to look good as new. The bar itself is 36" wide, perfect width for the front of a TJ. It actually comes with the bushings to mount in the TJ front crossmember, so it should be a direct bolt-on upgrade for them. There's a small chip out of the face of one of the bushings but nothing that affects function at all, and probably isn't even visible when installed.
The only difference between this and the AntiRock is that the arms don't have multiple holes for varying the rate/stiffness. All that's needed to change that would be to drill additional 1/2" holes along the length of the arms. I can go ahead and do this for the buyer if it'd make or break the sale.
Only reason I'm selling is that I have 2 identical setups and need to replace 1 set with a wider bar for the rear of my rig.
$225 obo locally, $250 shipped Located in Highland, MI, can be taken to Ann Arbor, Howell, or Fenton areas easily.
bbaXJ is offline
Old September 20th, 2011, 04:08 PM   #2
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Can you tell me the dia. of the bushings that slide into the frame and the width it is set-up for? I want to put one on my yj.
Thanks
RIP FULLSIZE4LIFE
SHARPMACHINE is offline
Old September 20th, 2011, 04:14 PM   #3
bbaXJ
Yooper In Training
bbaXJ's Avatar
I think the width of the frame/crossmember itself is around 32" but I'll double check that and the bushing diameter when I get home. I know I had originally purchased it for my Scrambler that had a custom frame 32" wide front and rear, but the kit is actually designed for a TJ frontend. New bushings could easily be bought or machined out of plastic if needed too.
Edit: Just checked the manufacturer website and it's designed for 87-06 YJ/TJ/LJ so it'll work on yours too. I thought the crossmember was the same for all but wasn't sure....looks like I was right
bbaXJ is offline
Old September 20th, 2011, 05:50 PM   #4
liv2mx
i like jungle gym's.
liv2mx's Avatar
pm becky she needs this.
liv2mx is offline
Old September 20th, 2011, 06:18 PM   #5
bbaXJ
Yooper In Training
bbaXJ's Avatar
Thanks, just sent her a text
bbaXJ is offline
Old September 20th, 2011, 06:25 PM   #6
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Great deal
H.o.r.e
bigbchevy is offline
Page generated in 0.19116 seconds with 41 queries
