Dodge Ram 2500 Trans and T Case - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 19th, 2011, 03:40 PM   #1
Kawierider
Kawierider's Avatar
Default Dodge Ram 2500 Trans and T Case
Ooops, posted in wrong forum please move or delete!
Transfer Case NP271D out of a 2005 dodge ram 2500, auto, cummins, SRW truck. ~130K miles. Worked great when pulled. shifts great. No gear or chain noise. no leaks. $400 obo.
Transmission 48RFE, out of a 2005 dodge ram 2500, cummins, ~130K miles. Overdrive housing failed and is not included. There is no damage to the sealing surface, or the front transmission housing. There is no reason to believe the front half of the trans (1,2, 3 and reverse) don't function properly, and the output shaft is straight and undamaged. The overdrive housing assembly (which bolts right on) can be purchased for ~350 dollars. I was going to keep this to build a performance trans off of, but have decided that I don't have the room to store it. The full transmission core cost is ~$500 dollars so even worse case you could assemble a full core in your garage and come out a hundred or two ahead. I'm asking $100 OBO
PM or email Tim.Vezina@gmail.com or text 313--995-0020 with questions
Last edited by Kawierider; September 19th, 2011 at 03:52 PM. Reason: Sorry, please move or delete.
Old September 19th, 2011, 09:45 PM   #2
unclemyke
I don't suppose you'd be looking for ANYTHING in trade?!
unclemyke is offline   Reply With Quote
Page generated in 0.20664 seconds with 29 queries
