Need help setting up throttle valve linkage -AMC360/tf727 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 18th, 2011, 08:22 PM   #1
huntstoomuch
Always chasing a big rack
huntstoomuch's Avatar
Default Need help setting up throttle valve linkage -AMC360/tf727
So I'm having trouble hooking up/adjusting the throttle valve linkage (what some people call a kick down cable) in my CJ7 with an Amc360/Tf727 combo. I'm in the process of converting from gas (carb) to propane with a used Gotpropane kit which uses a Holley base plate/throttle link. I'm working with a Lokar kick down linkage/cable.
After doing quite a bit of searching I think I understand the basics:
-At full throttle on the carb (when I say carb I mean mixer from here on) adjust the linkage so the throttle lever on the trans end is pulled fully towards the rear of the jeep.
-Do not allow the throttle lever on the transmission to limit the travel of the accelerator cable.
-At idle the lever on the the transmission needs to have very little to no slack
Here is the problem I'm having... The lever on the transmission has a few inches of travel but it seams to like to come to rest (with no linkage hooked up) somewhere in the middle of it's full range of travel. It's got me thinking there should be a spring that returns the throttle lever on the transmission all the way back at idle... Am I off base here? If a spring was hooked up I would have no problem adjusting the linkage within the specs listed above but with out the spring return I can't get the linkage in spec. So I'm guessing I need the spring or something is wrong with the throttle lever on the transmission of I just don't know what the hell I'm doing.
Someone PLEASE educate me before I trash a transmission.
huntstoomuch is offline   Reply With Quote
Page generated in 0.19366 seconds with 26 queries
