tubing tires - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2011, 09:09 PM   #1
special k
special k's Avatar
Default tubing tires
I've got a tire that is slightly too big of a hole to patch or plug, was thinking about tubing it before replacing, what are your opinions? Hole is deada center in the tread andis roughly 1/4". Will needyou to hold For driving and wheeling
Old September 17th, 2011, 09:26 PM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Seems like it wouldn't be a problem to plug that from the inside out
H.o.r.e
Old September 17th, 2011, 09:29 PM   #3
badbowtie
yeah a good tire shop will take the tire off and use a patch from the inside. wont have any issues
badbowtie is offline   Reply With Quote
Old September 17th, 2011, 09:38 PM   #4
yyj87
yyj87's Avatar
x10
Discount patched a 3/8 hole for me once in the side lug of a bfg at, ran the tire for another 20k without issue.
yyj87 is offline   Reply With Quote
Old September 25th, 2011, 09:02 PM   #5
chevfreak82
chevfreak82's Avatar
you have to have a smooth surface inside a tire for a tube no plugs or factory tags inside it will irriatate the tube put a hole in it rubbin back and forth have it patched and tubed depending on the place you take it some are pickier than others
chevfreak82 is offline   Reply With Quote
Old September 25th, 2011, 09:23 PM   #6
littletrucker
I'd hit that
littletrucker's Avatar
1/4 inch hole would be no problem for an inside plug patch.. especially in the center of the tread
Old September 25th, 2011, 09:44 PM   #7
Freak
Wheelin the HD
Freak's Avatar
Im with everyone else, patch it from the inside, tubes suck for any on the road driving.
Old September 25th, 2011, 09:59 PM   #8
special k
special k's Avatar
I ended up patch plugging it at work last monday. The hole ended up being smaller that I thought, was still under 1/4". Is still holding well
Old September 25th, 2011, 10:17 PM   #9
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
http://www.globalindustrial.com/p/to...campaignId=T9F
I've been using these over traditional patches. They're easier to get into the tire and hold forever... especially when you hot patch.
ckupq is offline   Reply With Quote
Old September 26th, 2011, 12:08 AM   #10
MichiganJeeper
Tube in Radial tire = nono
You can plug and patch it more then likely.
MichiganJeeper is offline   Reply With Quote
Old September 26th, 2011, 12:24 AM   #11
@_'-'
yup, mushroom plug FTW! its a combo patch/plug all in one.
@_'-' is offline   Reply With Quote
Old September 26th, 2011, 11:15 AM   #12
special k
special k's Avatar
that's what i used.
Old September 26th, 2011, 05:29 PM   #13
ckupq
ckupq's Avatar
I must been doing it all wrong when I bought those tubes that say "for radial tires" on them.
Page generated in 0.29636 seconds with 62 queries
