Wheel stuck to hub...at a loss on what to do - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2011, 03:08 PM   #21
1slo_camaro
LONG STORY SHORT, IM 23
1slo_camaro's Avatar
do not use heat!!! ill find a video floating around online where it shows what happens when heat is applied to an inflated tire. you heat the rim up and it expands everything then the tire explodes. they show everything. my suggestion is back the nuts off loose enough with a few threads left on a shit load of pb blaster and sledge on the back. or ive drove around my yard a few times with the lug nuts backed off and hard sharp turns at like 10-15mph
1slo_camaro is offline   Reply With Quote
Old September 17th, 2011, 03:14 PM   #22
1slo_camaro
Jump to 2:00..... yea listen to these dumbasses and take heat to the rim......
Old September 17th, 2011, 04:11 PM   #23
You might need to keep soaking it for a week.
Do you own an air chisel? Put a piece of scrap metal against the backside of the rim, and then hit that with an air chisel for a while.
Old September 17th, 2011, 04:12 PM   #24
He can just pull the valve core....
Old September 17th, 2011, 04:28 PM   #25
Freak
Wheelin the HD
Freak's Avatar
Won't heat hurt the wheel bearing?
Old September 17th, 2011, 04:37 PM   #26
1slo_camaro
please jump to 5:25, it kinda jumps right to using heat to expand the metal to make something slip off..... kinda like you dumbasses are telling him how to do it..
Haggar please jump right to 6 minutes
so to the OP be a dumbfuxk and listen to everyone else, or heed this warning and
DO NOT USE HEAT ANYWHERE NEAR OR AROUND YOUR RIM!!!
Old September 17th, 2011, 04:37 PM   #27
1slo_camaro
the wheel bearing? i dont think thats the issue at hand. i think the guy fucking killing himself is a little more important....
Old September 17th, 2011, 04:43 PM   #28
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
I always take a 4x4 about 30 inches long put up against wheel and tap liberals with sledge
dougstephvoor is offline   Reply With Quote
Old September 17th, 2011, 06:04 PM   #29
Freak
Wheelin the HD
Freak's Avatar
Bahhahaha. . . They welded on a heavy equiptment tire in that vidio and 22 hours later it blew! Thats crazy! The themal expansion happens so fast it can reset the bead!
Old September 17th, 2011, 06:12 PM   #30
Pipefitted
Super Noob
Pipefitted's Avatar
Forget WD-40 and PB Blaster, what you need to use is Kano Kroil. It's what we use in the refineries to break the unbreakable nuts loose.
http://www.kanolabs.com/google/
Pipefitted is offline   Reply With Quote
Old September 17th, 2011, 07:01 PM   #31
1slo_camaro
how do you figure 22 hours later dipshit? it was 2 minutes later. and whatever go ahead and use a torch on your rim. there will be one less dumbass on the face of the earth go ahead please do it
Old September 17th, 2011, 07:27 PM   #32
JoshuaCripe
JoshuaCripe's Avatar
Sorry to hear
JoshuaCripe is offline   Reply With Quote
Old September 17th, 2011, 08:22 PM   #33
yyj87
yyj87's Avatar
90 seconds with a map torch wont cause the tire to explode, 10 min with a torch will so before you decide to cut the wheel off remove the valve core!
Im looking for a troll Icon and cannot find it.
yyj87 is offline   Reply With Quote
Old September 17th, 2011, 10:46 PM   #34
Freak
Wheelin the HD
Freak's Avatar
Watch the whole video smartass, towards the end, they talk about the longest elapsed time, from welding, to detonation.
you posed it, you should have watched the whole thing.
Old September 18th, 2011, 08:54 AM   #35
1slo_camaro
yes the longest amount of time. ever. but it can also happen quicker.... whatever..... OP if you wanna be a dipshit and possibly take the chance of killing yourself or blowing a tire and ripping the corner of your car apart. go ahead use heat..... if you wanna do it the right way. try something else, or like everyone else said take it to a Big truck shop and let them deal with it...... You can't argue with a retard, they will bring you down to their level and beat you with experience.
Old September 19th, 2011, 12:37 PM   #36
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
4wd lo with the lugs loose. Do a shitload of launches and hard braking - it'll come off.
@clarkstoncracker
Old September 19th, 2011, 12:51 PM   #37
Bones
Bones's Avatar
x2. I wasn't suggesting using a torch to cut the wheel in half. You only need enough localized heat near the hub to break the corrosion bond, which isn't much. Then you should have no problem with a BFH or using the vehicles power steering to remove it.
Or if you are really worried, just remove the valve stem as previously mentioned.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 19th, 2011, 12:55 PM   #38
clarkstoncracker
lol
clarkstoncracker's Avatar
Dude, pulling the valve stem will act like a pressure release. You can't build up pressure in a tire if there is a 1/4" hole venting to the outside.
Old September 19th, 2011, 01:19 PM   #39
Freak
Wheelin the HD
Freak's Avatar
They did this in that video he posted its a chemical process in the tire that causes the problem, not the torch itself.
Old September 25th, 2011, 08:54 PM   #40
chevfreak82
chevfreak82's Avatar
you know what they say work smarter not harder lots of heat and a bfh from the back side heat and beat works every time heat around the hub you said you dont care about the wheel so do it to it.
chevfreak82 is offline   Reply With Quote
Page generated in 0.46564 seconds with 84 queries
