Wheel stuck to hub...at a loss on what to do - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2011, 09:35 AM   #1
Speedlaser18
Default Wheel stuck to hub...at a loss on what to do
Working on my wifes 98 4runner i got 3wheels off cant get drivers front to budge.
!st attempt was to soak it in pb blaster then beat tire with 8lb sludge hammer inside and outside..Didnt work.
2nd attempt was break lugnuts loose drive around parking lot stabbing the brakes...Didnt work
3rd attempt was Beat Rim (al alloy) with sludge hammer ...Didnt work
4.th attempt was a hail mary and we tried using shops forklift weight to budge wheel .All that did was knock toyota off jacks lol .
Gave up took it too discount tire and they couldnt remove it either....
So im at a loss on what to do...I dont care about the rim but would like to save tire since there only 3months old..
any help would be appreciated..
Rim is aluminum to a cast hub if that helps
Speedlaser18 is offline   Reply With Quote
Old September 17th, 2011, 09:39 AM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
BFH(big fukcing hammer) hit the tire
H.o.r.e
Old September 17th, 2011, 09:42 AM   #3
steelhd1
Hypnotized
steelhd1's Avatar
Torch the SOB
steelhd1 is offline   Reply With Quote
Old September 17th, 2011, 10:05 AM   #4
Klumpper
Fuck Cancer!
Originally Posted by steelhd1 View Post
Torch the SOB
x2, but may make difficult to save the tire. Rust buildup between the two metals will make a barrier so it will be difficult to burn the hub.
If not, apply generous heat and beat with hammer.
But I skipped the first question, does it HAVE to come off?
Klumpper is offline   Reply With Quote
Old September 17th, 2011, 10:07 AM   #5
in2deep
Hole tester
soak in wd40 over nite loosen lugs drive in tight circle fast worked for me a few times
Old September 17th, 2011, 10:13 AM   #6
OTR
OTR's Avatar
discount is pussys...if you have a commercial tire shop there (one that works on semi-trucks)j take it there...
OTR is offline   Reply With Quote
Old September 17th, 2011, 10:16 AM   #7
Speedlaser18
Ill gve that a try
The reason i want the tire off is incase i got a flat.I have a fullsize spare also new on a factory rim...But shit i cant break the old wheel loose...
The guys that said heat ...do i heat the rim till it turns orange?...or just hot?.....Bigchevy should i just beat it harder?...lol sore already
Old September 17th, 2011, 10:22 AM   #8
OTR
OTR's Avatar
Big truck shops deal alot with that...they'll get it with no damage to anything...alum wheels on semis are notorious for acting like someone welded the damn things on...just a little heat should do the trick...your pb blaster might flame up a little though
Old September 17th, 2011, 10:42 AM   #9
BlzrNick
Built not bought
BlzrNick's Avatar
We come across this sometimes at work. All we do is take out 12lb sledge hammer and hit the tire as hard as possible from the back side. It usually only takes one hit if not two will have it off.
BlzrNick is offline   Reply With Quote
Old September 17th, 2011, 10:47 AM   #10
koochman450r
koochman450r's Avatar
i work on semis and the tires get stuck on real bad sometimes. Especially on the freightliners. We use a lot of pb and a big sledge hammer. Like 15lbs or greater. Beat it from the back side. We also used a chain hooked to a forklift and jerked the wheel off. That worked because it was a rear and we left the other 6 tires on the rear.
you won this battle.
Old September 17th, 2011, 10:53 AM   #11
Freak
Wheelin the HD
Freak's Avatar
This is why I tell breakdown at my company "I'm not a freakin mechanic" every time they ask me to do something.
Old September 17th, 2011, 11:04 AM   #12
JoshuaCripe
JoshuaCripe's Avatar
All good info beyond the realm of whats normal.....hell im taking notes for future refereance....Spedlaser18 is maybe 150lbs lol i think the 15lb sledge is outta the question hahah
JoshuaCripe is offline   Reply With Quote
Old September 17th, 2011, 11:12 AM   #13
badbowtie
Get a big pry bar and go from the back side. pry against a control arm etc and the back of the wheel. should pop right off. never had any wheel i couldnt get off.
badbowtie is offline   Reply With Quote
Old September 17th, 2011, 11:44 AM   #14
sufferingant
sufferingant's Avatar
I've had great luck with repeatedly slamming the brakes at ~40mph. Just leave the lugnuts on but backed out like 5 turns.
When I finally got my trucks wheels off, I put wheel bearing grease on the hub before putting them back on.
sufferingant is offline   Reply With Quote
Old September 17th, 2011, 01:08 PM   #15
I suck cocks. Lots of them.
locally famous
my buddies silverado did that. big hammer, and use anti-seize next time.
also, 150lbs might not be enough ass, time to phone a friend?
Old September 17th, 2011, 02:05 PM   #16
deerebowtie
Unchained
deerebowtie's Avatar
put the wheels back on, loosen the lug nuts a little bit on the tire thats the problem, and do a reverse slide on the road outside your driveway. works every time.
Old September 17th, 2011, 02:32 PM   #17
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
if nothing else works hook a snatch strap to the wheel in question and loosen all the lugnuts, and yank it with another vehicle. i had a old dodge neon years ago i couldn't get the front tire off. broke all 5 studs off it was so rusty and the wheel wouldn't come off. thats what i ended up doing.
Old September 17th, 2011, 02:36 PM   #18
Freak
Wheelin the HD
Freak's Avatar
Sounds like lots of good ways to fukc up the alignment.
Old September 17th, 2011, 02:42 PM   #19
kevinr839
kevinr839's Avatar
I have had to put a 2x4 between the rim and frame before and start the vehicle and trun the wheel. Usaully that works for me. The extra power from the ps pump usually gives it enough force to break it loose.
kevinr839 is offline   Reply With Quote
Old September 17th, 2011, 02:44 PM   #20
Bones
Bones's Avatar
use heat
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Page generated in 0.40085 seconds with 83 queries
