Tahoe Blend Door Actuator - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 16th, 2011, 11:20 AM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default Tahoe Blend Door Actuator
Anybody change these? It's on a 2004 with dual climate control and they are both acting up and need to be changed. Dealer wants a crap tone of money to do this, and I can't find any instructions on line about this job.
Old September 16th, 2011, 11:25 AM   #2
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Does this help maybe? Even though it sounds like the guys lips don't touch when he talks.
Old September 16th, 2011, 11:38 AM   #3
shawn
shawn's Avatar
Yeah, looks like the left one is easy to replace. But the right one? Where is it? Do these have to go through a calibration after installation.
Old September 16th, 2011, 11:41 AM   #4
Ridin Dirty
I'm not certain. I used my phone a friend but he didn't answer. I'll let you know what he says when he calls me back. He has been the trim guy at a Chevy dealership for 20+ yrs. I remember doing the one in my 99 and it ended up being a stupid little plastic gear. Is yours "clicking" very loudly?
Old September 16th, 2011, 11:43 AM   #5
davidkassie
davidkassie's Avatar
on your 04, u need to remove dash almost all the way out, not too bad if u are patient and somewhat experienced.. there are two bolts that are pretty hidden, sitting in the drivers seat, the two bolts go straight down under windshield almost center with column, they are 15 mm heads, other than that, do not remove radio, cluster, etc. just unbolt main frame assy and tilt away from passenger side corner, can reach both, just be careful, there are lots of bolts, hopefully u don't have center console, cuz that sucks
davidkassie is offline   Reply With Quote
Old September 16th, 2011, 11:44 AM   #6
davidkassie
yeah calibration is probably necessary, maybe a way to do it by removing a certain fuse, etc... google it
Old September 16th, 2011, 01:33 PM   #7
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
you didn't say what going on with the doors? is it just the reaction time? or are they getting stuck?
I was going to tell you to drop the blower out and use a shop vac to clean out the debris that builds up under there. might save a ton of time?
Yetti
Old September 16th, 2011, 03:49 PM   #8
shawn
shawn's Avatar
This is a friends Tahoe. It is acting very sporadic, not responding, never consistent. I've read where the wipers inside get dirty and stop making good contact. It's not grinding yet, I've replaced a couple on other vehicles that were grinding and broke.
So, both of them are under the dash? I thought one of them was over by the gas pedal.
Old September 16th, 2011, 05:38 PM   #9
blownexploder94
Todd
blownexploder94's Avatar
Default .
Removal and Install procedure for right side.
Name:	right side removal.jpg
ID:	83529   Click image for larger version
Name:	right side install.jpg
Old September 16th, 2011, 05:41 PM   #10
blownexploder94
Todd
Default Re-Calibration without scan tool
Procedure to Re-Cal W/O scantool
Name:	HVAC Re-Calibration.jpg
Old September 16th, 2011, 06:24 PM   #11
shawn
shawn's Avatar
Awesome! Thanks. But where is that right actuator at? That says nothing about removing the dash. What is the carrier?
Old September 16th, 2011, 06:53 PM   #12
blownexploder94
Todd
Default Hvac
Well after reading through it, You have to end up pulling the entire dash out of the truck.
Old September 16th, 2011, 07:14 PM   #13
shawn
shawn's Avatar
UHG!!!1!
Looks like I got my work cut out for me. Thanks for the instructions!
Old September 17th, 2011, 07:53 AM   #14
Yetti
Yetti's Avatar
since you don't know the truck, it might be as simple as a pencil stuck down a vent. look for debris in the duct work as you take each piece off
Yetti
Page generated in 0.28214 seconds with 67 queries
