xj which SYE kit can i run with a cable speedo - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 15th, 2011, 10:22 PM   #1
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
Default xj which SYE kit can i run with a cable speedo
i dont really want to have to change out my cable drive speedo. i just spent $ for the new cable and speedo gear to make it read correct. i am looking ar doing a bigger lift and sye kit over winter and i see alot of them want the electric speedo conversion. are there any that i can keep my cable and if so which is the best one? thanks for any help
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old September 15th, 2011, 10:57 PM   #2
capndaveyj
ive got a 88 cable drivin xj i got a rugged ridge one off ebay and im running my normal speedo gear and cable with no issue
capndaveyj is offline   Reply With Quote
Old September 16th, 2011, 08:02 PM   #3
CHEROKEEMUDMAN01
mellow yellow
i look at one of those. just cant believe that most i looked at want u to run electric speedo
Old September 16th, 2011, 08:07 PM   #4
Fraser
Fraser's Avatar
really? i dont think cable/ electric would matter- they both use the gear
Old September 16th, 2011, 08:19 PM   #5
CHEROKEEMUDMAN01
mellow yellow
all the mega short kits say electronic speedo only. i didnt understand that eather cause both do use a gear one is just shorter than other.
Old September 16th, 2011, 09:16 PM   #6
Fraser
Fraser's Avatar
you need a mega short in a cherokee? It looks like the jb conversions super short sye uses a gm speed sensor, which reads off of a tone wheel instead of the gear
Old September 23rd, 2011, 11:39 PM   #7
CHEROKEEMUDMAN01
mellow yellow
plan was to go with alot of lift about 12" or so so i can run 37 on it. figured the shorter the beter for driveshaft angle since i do enjoy driving it to work now and then
Old September 24th, 2011, 12:09 AM   #8
capndaveyj
im running 11 inches or so with 38s on a normal sye no issues
Old September 24th, 2011, 09:17 AM   #9
CHEROKEEMUDMAN01
mellow yellow
good to know thank you. i just am one of them guys that overkills everything and overthinks everything and usually end up with a headach lol
Old September 24th, 2011, 12:45 PM   #10
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
None of the mega shorts usa a gear, they all use a tone ting and work for electronic speedo only.
The regular SYE's use a gear and will work with electronic or mechanical speedos.
I'd recommend this one:
NP231 Slip Yoke Eliminators - $167.95 - Great Lakes 4x4. The largest offroad forum in the Midwest
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Page generated in 0.20189 seconds with 54 queries
