Wiring in an electronic carb choke - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 15th, 2011, 10:46 AM   #1
Squishy
Needs More Cowbell
Squishy's Avatar
Send a message via AIM to Squishy
Default Wiring in an electronic carb choke
It's a Holley 600 or 650 with an electronic choke on it - It's grounded, but has no power to it. What's a good power source to tap into for this? It's on an 85 Chevy with a 400 small block. Not sure what to tie it into.
Squishy is offline   Reply With Quote
Old September 15th, 2011, 11:36 AM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Run it through a relay that is powered by your alternator field wire - that way, you don't power the coil if you're not moving the engine. i.e. sitting in the car, engine stopped with the ignition in ACC
@clarkstoncracker
Old September 15th, 2011, 11:36 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
You could tap into the distributor power feed.
Old September 15th, 2011, 11:57 AM   #4
Squishy
Needs More Cowbell
Squishy's Avatar
Someone had told me find one of the ignition wires, but I'd be damned if I can follow anything in this truck more than 1 foot. Both of those may work out fine - At least those, I can get to easily enough.
I've never had to wire a relay in though, I'd be lost on that one.
Old September 15th, 2011, 12:10 PM   #5
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
[QUOTE=Squishy;2781681]Someone had told me find one of the ignition wires, but I'd be damned if I can follow anything in this truck more than 1 foot. Both of those may work out fine - At least those, I can get to easily enough.
I've never had to wire a relay in though, I'd be lost on that one.[/QUOTE]
Google is your friend. Just ask him.
Old September 15th, 2011, 12:24 PM   #6
Squishy
Needs More Cowbell
Squishy's Avatar
[quote=SANDVIPR;2781691]
Already did - Found a diagram I can use rather easily. Managed to find the Holley install instructions, too. Suppose I should've done that in the first place.
Old September 15th, 2011, 01:24 PM   #7
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
LOL - does holley suggest a relay?
@clarkstoncracker
Old September 15th, 2011, 02:11 PM   #8
Squishy
Needs More Cowbell
Squishy's Avatar
Doesn't look like it. Just says wire to 12V power source.
Old September 15th, 2011, 03:19 PM   #9
I've never used a relay, just used coil or any other keyed hot.
Page generated in 0.22460 seconds with 50 queries
