97 chevy cummins swap - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 12th, 2013, 09:43 AM   #161
extremajoe
the man,myth,legend
extremajoe's Avatar
looks like you got a bed full of dead bodies
extremajoe is offline   Reply With Quote
Old March 12th, 2013, 01:28 PM   #162
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Yea buddy
sbcrichie is offline   Reply With Quote
Old March 12th, 2013, 02:16 PM   #163
fabricator
throttle jockey
fabricator's Avatar
do you happen to have the old fan hub around still? i think i need to do just the opposite with the fan in my project
fabricator is offline   Reply With Quote
Old March 12th, 2013, 03:14 PM   #164
firehawk
Live Action!
firehawk's Avatar
How are the airbags attached to the axle? A bracket that is welded to the axle that extends down and back? Like a shelf off the back of the axle?
Old March 12th, 2013, 07:13 PM   #165
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yes i do
Old March 12th, 2013, 07:15 PM   #166
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yes exactly, i am a little concerned about it putting added stress on the poly bushings in the links because they are mounted behind the axle so they are always trying to rotated pinion up but i figured we will see how long the poly bushings last, it will prob be fine.
Old March 14th, 2013, 02:14 PM   #167
Red97
The truck looks great. How well does the offset wishbone upper link control the axle? I was really wanting to do a airbag wishbone 4 link on the rear of my 97 with the stock tank. I am lifted about 8"
Red97 is offline   Reply With Quote
Old March 14th, 2013, 07:46 PM   #168
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
seems fine does burnouts just fine i did reinforce the crossmember that the wish bone goes too, i ran a tube from it to the frame.
Old February 27th, 2015, 04:31 PM   #169
Grassman
2jz specialist
Grassman's Avatar
whats this look like these days?
all done? happy with final product?
Old February 27th, 2015, 07:24 PM   #170
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Looks pretty much the same, drive it daily except in the winter. got a winter beater so I didn't have to drive it in the salt.
needs stiffer motor mounts, I used stock first gen rubber mounts and the motor moves too much. 4.10 still suck with 28" tires.
getting a little bored with it, toyed with the idea of raising up to stock height and trying to squeeze some 35's on it and go for the chase truck look. but who knows.
Old June 13th, 2015, 05:52 PM   #171
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Time for a change. Got 35's on it and it is still lowered. Still gotta flare out the bedsides a couple inches and build some bumpers.
Old June 14th, 2015, 09:46 PM   #172
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Still jealous. Looks good.
@0Toncaddy don't get too big of a boner.
*2007 Rubicon
*2006 Duramax
Old February 16th, 2016, 11:10 AM   #173
camoII
camoII's Avatar
Awesome build. I may have some questions for you soon as I'm about ready for the same swap. Mine is a diesel truck though so it may be slightly easier.
camoII is offline   Reply With Quote
Old February 16th, 2016, 01:10 PM   #174
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yes I would think your swap will be easier starting with a diesel truck.
Old February 16th, 2016, 02:06 PM   #175
Lousypirate
Whoop Whoop
Lousypirate's Avatar
I take it you trimmed the front fender to fit the 35?
The Kernel (46 CJ2a)
Wow, i would lick those...
Old February 16th, 2016, 02:31 PM   #176
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
they are fiberglass fenders on the front, no trimming to the fender but quite a bit of work to the inner fender structure to clear 35. I don't have a pic but the stock rear bedsides are now pulled out a couple inches to clear the tires and full bump.
Old February 16th, 2016, 10:52 PM   #177
Lousypirate
Whoop Whoop
Think a 35 would tuck on a 3500 dually stock height to lightly lifted? Ie crank torsion bars
Old February 17th, 2016, 06:11 AM   #178
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
depends on wheel offset and width of tire, and if you plan on turning sharp.
on another note my torsion bar crossmember took a shit, and could not find a replacement, so I bought a new one from gm for a new body style duramax worked out real slick it cleared the tcase with no mods, the original one I had to clearance to clear tcase. also took out the one ton torsion bars and put in half ton torsion bars rides even nicer now.
Old February 17th, 2016, 07:03 AM   #179
Lousypirate
Whoop Whoop
Hmm, I'll have to consider that. I've been toying with going to single tires on my 98 3500 dually. It has a dually width service box on it, so I'm not sure how it'd look. It already has 4.10's which the current 225s aren't cutting the mustard I don't think I'll ever overload a single rear tire load range E on it, but I never know...
Page generated in 0.31858 seconds with 81 queries
