97 chevy cummins swap - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 20th, 2011, 08:56 AM   #101
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Thanks!
Working on bed yesterday and today maybe with any luck will have some paint on it soon.
sbcrichie is offline   Reply With Quote
Old January 11th, 2012, 08:36 PM   #102
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I finally got a bed on this thing. Now if i can only get the cab painted, ooh well i guess i will rock the police truck while i save up some more pennies
Name:	cummins swap bed.jpg
ID:	87818   Click image for larger version
Name:	cummins swap bed2.jpg
Old January 11th, 2012, 08:48 PM   #103
TanTahoe
TanTahoe's Avatar
Very Nice set-up. I Like the OBS crew cabs.
TanTahoe is offline   Reply With Quote
Old January 11th, 2012, 09:03 PM   #104
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Thanks! Yea i like them too they are quite roomy, not as luxurious as the new ones but way more affordable.
Old January 11th, 2012, 09:24 PM   #105
knixon804
THE GENERAL
knixon804's Avatar
well hows it run? any real changes you had to do to it?
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JKU UD60s, 40" TRAIL GRAPPLERS, MACHETE BEADLOCKS, AEV BLOWER
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Old January 11th, 2012, 09:48 PM   #106
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
It seems to run pretty good. I havent really done anything to it since i started driving it a month or two ago. It is over geared with 4.10 and stock dia tires, i had the cruise set at 70 on the highway for about a couple of hours 2500 rpm the whole time. The gearing is nice for towing though since i really dont tow over 65 anyways but would have better economy with different gearing. I would like to find an old brownie box to put behind the tcase then i would have more gearing options and still keep the low gearing for towing. The stock turbo doesnt like how i have the pump fueling now so i worked out a deal with a diesel shop too build me a hybrid turbo out of used parts in trade for the cummins trans that came with the motor. The custom shifter i made was noisy as hell so i drilled a hole and filled it full of silicone and that quieted it right down. I did also have to put a new ignition switch in it too.
list of things to do when i have time
locate and fix power steering leak (i think the steering box)
all new brakes on front
put fan back on ( yes i have been driving it with no fan on the motor, cools quite easily)
some suspension work, prob not air bags tired of working on it for now
install the pyro and boost gauges
Old January 15th, 2012, 09:25 PM   #107
drew454u
drew454u's Avatar
just wanted to say nice work, its looks real good. I am gonna PM you cause i have a ton of little questions and dont wanna clog your thread. I am about to start my own swap and have some things that i cant find answers too.
I also looked at your facebook page for r&r fabwerks and you do some amazing fabrication, I can weld very well but some of the stuff i have seen from you makes me very jealous.
drew454u is offline   Reply With Quote
Old January 15th, 2012, 09:40 PM   #108
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Thanks! Happy too help
Old July 24th, 2012, 09:21 PM   #109
m.kasperan
Any updates to this project? Nice build.
m.kasperan is offline   Reply With Quote
Old July 24th, 2012, 09:29 PM   #110
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Yea been doing small stuff on it while driving it. New hybrid turbo, got air conditioning g working, put a roll pan on it and moved hitch up behind roll pan, and lots of other small things that a truck with 250,000 miles on it needs. It is getting dropped off at painters Friday so I will post some pics when I get it back from painter.
Old July 24th, 2012, 10:07 PM   #111
Elusive
Elusive's Avatar
Can't wait to see it! I want this truck! Very nice job on the conversion.
Elusive is offline   Reply With Quote
Old July 25th, 2012, 05:18 AM   #112
extremajoe
the man,myth,legend
extremajoe's Avatar
Don't paint it, never seen a cop truck like that before! Just get a pillar light on both sides then it would be complete!
All blitz I hope!?
extremajoe is offline   Reply With Quote
Old July 25th, 2012, 05:52 AM   #113
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Yep all blitz black. Bye bye cop truck!
Old July 25th, 2012, 08:25 PM   #114
m.kasperan
I have the same truck...I just order the mounts from Blake's today and the NV4500 should be done next week. I can't wait to get started on it. Did you ever do the bags in the front end?
Old July 25th, 2012, 08:27 PM   #115
m.kasperan
Also what size tire is on your truck?
Old July 25th, 2012, 08:30 PM   #116
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
No I got burned out on the project and just wanted to drive it for a while. The truck is lowered now though I did 4" hanger drop on the rear and machined out the torsion bar crossmember to lower the front.
Old July 25th, 2012, 08:33 PM   #117
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I can't remember tire size off the top of my head. They are stock diameter just wider and on a h2 wheel
Old July 25th, 2012, 08:34 PM   #118
m.kasperan
Cool looking forward to seeing the pics after paint. How's it drive? Fun? MPG? Is it your DD?
Old July 25th, 2012, 08:38 PM   #119
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Yes it is a blast to drive, it's no big power house but tows good and is fun to drive. Im still gonna go farther on the full fuel screw just haven't had time to mess with it. Yes it is my daily driver tow vehicle. It gets around 16 normal driving and 13 towing but I drive it hard all the time and the 4.10 gears with short tires kill mpg.
Old July 25th, 2012, 08:42 PM   #120
m.kasperan
What do you tow with it? I pull a 14ft enclosed (11,000 lbs. truck and trailer) around all day with mine and the 5.7 sucks!!!! I also have a 31ft 5th wheel camper. 13 towing would be nice I was hoping for a little more to be honest.
Page generated in 0.49072 seconds with 84 queries
