97 chevy cummins swap - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 8th, 2011, 10:25 PM   #61
special k
special k's Avatar
That's a real nice looking swap. Nice work and real nice welds!!! Keep up the good work!!! I'm jealous!!!
Old October 9th, 2011, 08:01 AM   #62
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
thanks guys!
sbcrichie is offline   Reply With Quote
Old October 12th, 2011, 09:40 PM   #63
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I got the coolers and pipping all wraped up, just waiting on a 3" intake horn to complete the 3" intercooler pipping.
I couldnt take all the shiny aluminum it just wasnt looking right on this project. So i got out the scotch brite and blitz black.
Name:	cummins swap cooling 6.jpg
ID:	84579   Click image for larger version
Name:	cummins swap cooling 5.jpg
ID:	84580   Click image for larger version
Name:	cummins swap cooling 3.jpg
ID:	84581   Click image for larger version
Name:	cummins swap cooling 4.jpg
ID:	84582   Click image for larger version
Name:	cummins swap cooling 2.jpg
Name:	cummins swap cooling.jpg
ID:	84584   Click image for larger version
Name:	cummins swap cooling 7.jpg
Old October 12th, 2011, 09:48 PM   #64
Dazz
Dazz's Avatar
Send a message via MSN to Dazz Send a message via Skype™ to Dazz
Dam looks great!
Dazz is offline   Reply With Quote
Old October 12th, 2011, 09:57 PM   #65
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
thanks!
Old October 12th, 2011, 10:02 PM   #66
Strangler
Strangler's Avatar
Old October 12th, 2011, 10:07 PM   #67
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
thanks!
Old October 13th, 2011, 03:38 PM   #68
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Its better than porn!!! Love the build.
Old October 13th, 2011, 06:20 PM   #69
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Thanks!
Old October 21st, 2011, 07:49 AM   #70
extremajoe
the man,myth,legend
extremajoe's Avatar
Is this thing on the road yet?? whats the hold up!?
looks sweet!
extremajoe is offline   Reply With Quote
Old October 22nd, 2011, 10:37 AM   #71
fabricator
throttle jockey
fabricator's Avatar
looks good. maybe i missed it, but what kind of intercooler is that?
fabricator is offline   Reply With Quote
Old October 22nd, 2011, 05:37 PM   #72
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Not sure on the intercooler it had a gm part number i think it was out of a gm mini semi thingy cant think of what they are called, i cut the tanks off and built my own tanks.
Old October 22nd, 2011, 05:39 PM   #73
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
looks sweet!
I will have an update soon i ran into some problems
Old October 23rd, 2011, 06:21 PM   #74
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Well i got the hood on and the fan blade was too high so i had to use a different fan hub on the engine. I got it fired up and took it for a spin and the slight miss never cleared up I was hopeing there was just some air in the fuel system, so we found #5 had the miss so we swapped the nozzle/injector with a different cylinder and the miss moved to that cylinder so i have to send that injector out and have it gone thru or buy a new injector. I did get the tach working ran it off the tach pulse on the alternator to a dakota digital tach module and got it dialed in to the right rpm. Also tryed the cruise control while on the road test and that worked great. So as far as wiring goes all that is left to try is the a/c but i havent charged that up yet to try it, and i need to finish up the heat grid wiring, I have the solenoid on the fire wall all wired up just have to wire in the timer, I got a volkswagen glow plug timer that will turn on the heat grid when the key is turned on and shut it off after 20 secs.
Name:	chevy cummins swap fan hub.jpg
Old November 2nd, 2011, 06:21 AM   #75
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Well the different fan hub also moved the fan a half inch closer to the radiator so i had to machine a spacer to space the fan of off the clutch. I a got a new injector and the motor seems to run good now, i have been driving it for a couple days now and i will say this, the rotary pump motor is a pooch in stock form! planning on fixing that this weekend with a governor spring, star wheel adjustment, fuel pin rotate, and full fuel screw. i will get more pics this week.
Name:	chevy cummins swap fan spacer.jpg
Old November 2nd, 2011, 10:00 AM   #76
Raymo
Square Peg
Raymo's Avatar
Send a message via AIM to Raymo
They are terrible when not messed with. I will say though, that the governor spring is a night and day difference, and a great mod for only $20. I went from foot-to-the-floor just to maintain 55mph to barely touching the pedal.
I just hope for your sake you didn't get a pump like mine... Half a turn on the fuel screw and it was bottomed on the o-ring that seals it to the pump top
Raymo is offline   Reply With Quote
Old November 2nd, 2011, 07:49 PM   #77
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
What all have you done to your pump? Are you happy with the power output now? have you change exhaust housings or done any other mods?
Old November 6th, 2011, 07:22 PM   #78
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Well i did the pump mods this weekend and WOW! did the 3200 gov spring turned the star wheel a 1/4 turn (thats all i could go and it was bottomed), turned the stock fuel pin to the deep side, and turned the full fuel screw in unknown amount but i think i can still go further. i still want to check fuel pin travel and possibly make the plastic washer thinner so i get more travel and maybe turn the full fuel screw some more but i dont have a pyro on it yet so i will prob roll with this for now. I cant believe the difference very fun to drive now it will easily run with a stock 24v. seat of the pants its hard to compare to my old 24v truck it had 3.55 gears and 35" tires, this truck has 4.10 gears and stock diameter tires on it, but feels quicker than the truck did.
Old November 7th, 2011, 11:15 AM   #79
not sure
no wait! my name is joe
not sure's Avatar
ok ive seen you driving this thing around town you better stop at tuffy so all us can drool over it. seriously
not sure is offline   Reply With Quote
Old November 7th, 2011, 11:39 AM   #80
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
will do! what bay are you usually in?
Page generated in 0.53859 seconds with 84 queries
