97 chevy cummins swap - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 25th, 2011, 07:57 PM   #41
boggin-machine
boggin-machine's Avatar
i am very jelous on this build. it makes me really wanna start one bad!
Old September 25th, 2011, 08:19 PM   #42
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
get to it and do it! Im thinking it would be easier to do on a 6.5 turbo diesel. Should be alot less work and there are plenty of those blown up out there.
sbcrichie is offline   Reply With Quote
Old September 25th, 2011, 08:28 PM   #43
boggin-machine
ya i agree. i would like to do it in a quad cab truck as well. i would also like a stick. i guess i gotta start watching to see whats out there for one. i just think i am to picky and would want a newer everyday diesel. much more comfy is all. i do alot of driving so i need a comfy truck.
Old September 25th, 2011, 08:34 PM   #44
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yea the newer body style would be a sweet conversion i just couldnt swing it and didnt have time to wait around looking for a deal on one with a blown up motor.
Old October 5th, 2011, 09:17 PM   #45
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I have been making steady progress on this got the wiring pretty much done, just have to wire up the dakota digital tack module to run my tach off the alternator, and wire up a timer to the heat grid. gonna try to use a volkswagen glow plug timer to cycle the heat grid for 20 seconds when the key is turned on. the volkswagen timer is the cheapest thing i could find for a timer, i have a 80 amp solenoid on the fire wall that the timer will switch on and off. I had the engine fired up just to check some of the wiring had a bunch of air in the fuel system and after being unsuccesful at bleeding it i finally found a air leak on the rubber line that hooks the pick up tube to the sending unit assembly, the hose clamp i used cut the rubber line so i put on a new piece of rubber hose and used a fuel injection hose clamp. Then the motor smoothed out and would rev up. Hoping to get the radiator, intercooler and piping all buttoned up and installed this weekend.
start of the wiring
all the wiring that i removed, didnt get a pic of the finished wiring yet but i will
i dont have any good places around to help with the ac fittings and hoses so i just welded the compressor fittings to what i had to get me going for now. i know its kind of hack but ohh well easy to change later. I used a accumulator from a 95 chevy for the different hose locations thinking they took the same hose fitting i was wrong to had to find the right fitting and get it crimped on my hose. Ac should be all done now when i get the core support and condenser back on.
Name:	cummins swap wiring 1.jpg
ID:	84239   Click image for larger version
Name:	cummins swap wiring 2.jpg
ID:	84240   Click image for larger version
Name:	cummins swap ac 3.jpg
ID:	84241   Click image for larger version
Name:	cummins swap ac 2.jpg
Old October 6th, 2011, 12:52 AM   #46
Dazz
Dazz's Avatar
Send a message via MSN to Dazz Send a message via Skype™ to Dazz
Hack job? I say innovative
Dazz is offline   Reply With Quote
Old October 6th, 2011, 05:48 AM   #47
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
lol! thanks
Old October 6th, 2011, 06:49 AM   #48
caveman
GeoDude
caveman's Avatar
car quest has a real fancy AC hose tool, the fittings are pricy though.
Old October 6th, 2011, 07:02 AM   #49
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yea thats were i got some of the fittings but they did not have the big die to do one of the crimps so i had to go to napa. And as much as i think palmer is a good guy he was not much help with finding the fittings and i did not have the patience to dig thru the big book for very long.
Old October 6th, 2011, 07:04 AM   #50
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I figure now that i have something that should work i can take the hoses off someday and take them to a ac place and say i need this but make it look nicer!
Old October 6th, 2011, 07:00 PM   #51
motox168
Bare Bones Offroad
motox168's Avatar
looks real good rich
motox168 is offline   Reply With Quote
Old October 6th, 2011, 07:08 PM   #52
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
thanks!
Old October 6th, 2011, 07:09 PM   #53
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
nice build!!!!
RIP FULLSIZE4LIFE
Old October 6th, 2011, 07:56 PM   #54
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
thanks
Old October 7th, 2011, 12:53 PM   #55
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
LOL, years ago when I worked at the old Napa-turned-Auto Value in White Pigeon, I used to make all kindsa hoses for the local farmers.
@clarkstoncracker
Old October 7th, 2011, 12:57 PM   #56
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
white pigeon? wonder if i know you?
Old October 7th, 2011, 01:11 PM   #57
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Live in Bulldog country for awhile and worked between WP & Constantine while at Glen Oaks in the late 80's
@clarkstoncracker
Old October 7th, 2011, 08:00 PM   #58
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
a little before my time, i did the glen oaks thing in the late 90's. Good move getting out of this area! lol
Old October 8th, 2011, 09:07 PM   #59
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Made some progress on the coolers today. Hit up my favorite yard for some assorted rubber mounts to mount everything, you cant beat a hand full of factory mounts for a couple of bucks. Hopefully tommorow can get the lower water necks fabed up and start on the intercooler pipping. Gotta get a fan blade too so i can makes sure it clears the radiator.
Name:	chevy cummins coolers.jpg
ID:	84322   Click image for larger version
Name:	chevy cummins coolers 2.jpg
ID:	84323   Click image for larger version
Name:	chevy cummins coolers 3.jpg
ID:	84324   Click image for larger version
Name:	chevy cummins coolers 4.jpg
Old October 8th, 2011, 10:18 PM   #60
tator
tator's Avatar
looking good, let me know if you need a hand with anything or need anything machined up. feels like ive been living at the shop lately.
tator is offline   Reply With Quote
Page generated in 0.26909 seconds with 84 queries
