97 chevy cummins swap - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 16th, 2011, 10:35 PM   #21
Raymo
Square Peg
Raymo's Avatar
Send a message via AIM to Raymo
AutoWorld engine mounts?
Those are the best pics I've seen to show how the engine fits down in the chassis with the IFS intact.
Coming along nicely.
Any thought into how you're hooking the hydroboost back up yet?
Raymo is offline   Reply With Quote
Old September 17th, 2011, 07:56 AM   #22
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
No the auto world mounts are too over priced for me so i was going to build my own mounts untill I found a shop called blakes diesel care he makes the mounts for 95$, I didnt see any reason to take the time to figure out the best spot for the engine placement and build the mounts for that price. The mounts come with a engine bracket and a plate to weld to the chassis then you drill the center hole through and use a first gen rubber mount. As far as the hydroboost you can either use the gm resivior on the dodge pump or you can just tee the return lines together and use the stock dodge pump and resivior.
sbcrichie is offline   Reply With Quote
Old September 17th, 2011, 08:41 AM   #23
Raymo
Square Peg
Raymo's Avatar
Yup, AW mounts and the others are nuts, I built my own but now I wish I'd known about the ones you bought!
I also used the Dodge rubbers, but after 4k miles they're junk There's a guy I found from the 1stgen forum that makes a Poly mount set for $100, I want to give those a try sometime soon.
I used the GM reservior, and while a little tight, it looks awesome.
Old September 17th, 2011, 09:57 AM   #24
Elusive
Elusive's Avatar
Awesome project!
Elusive is offline   Reply With Quote
Old September 17th, 2011, 10:06 AM   #25
knixon804
THE GENERAL
knixon804's Avatar
Sweet
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JKU UD60s, 40" TRAIL GRAPPLERS, MACHETE BEADLOCKS, AEV BLOWER
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Old September 17th, 2011, 07:57 PM   #26
caveman
GeoDude
caveman's Avatar
Originally Posted by sbcrichie View Post
Pics? If you live in sturgis you can just come out and see it!
i'm not worthy, i'm not worthy, i'm not worthy
Old September 17th, 2011, 08:48 PM   #27
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
I got the ac bracketry buttoned up, serp belt on, looked into the some fittings for the ac compressor, and got the down pipe welded up.
Name:	cummins swap 16.jpg
ID:	83582   Click image for larger version
Name:	cummins swap 17.jpg
ID:	83583   Click image for larger version
Name:	cummins swap 18.jpg
ID:	83584   Click image for larger version
Name:	cummins swap 19.jpg
ID:	83585   Click image for larger version
Name:	cummins swap 20.jpg
Name:	cummins swap 21.jpg
Old September 17th, 2011, 08:54 PM   #28
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Thanks for the heads up on the mounts I will keep an eye on them.
Old September 24th, 2011, 08:18 PM   #29
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
made a heat shield for the down pipe and mounted the 95 accumulator. The 95 accumulator has different hose placements so the hoses clear the down pipe better.
made this bracket for the gm alternator
bad pic but you can see where i machined the stock water neck to place the gm alternator
got the throttle cable and cruise control cable hooked up. i used a throttle cable for a throttle body truck instead of the vortec truck, you can use either cable but mine was worn out so i figured i would replace with this one since it is a little shorter than the vortec
had to move the shifter hole back about 4" so i made this plate to cover up the old hole
the stock shift lever would have hit the console so instead of trying to bend the lever that goes into the tranny i built a hotrod kenworth wanna be shifter
Name:	cummins swap 26.jpg
ID:	83820   Click image for larger version
Name:	cummins swap 27.jpg
ID:	83821   Click image for larger version
Name:	cummins swap 28.jpg
ID:	83822   Click image for larger version
Name:	cummins swap 24.jpg
ID:	83823   Click image for larger version
Name:	cummins swap 25.jpg
Name:	cummins swap 29.jpg
ID:	83825   Click image for larger version
Name:	cummins swap 23.jpg
ID:	83826   Click image for larger version
Name:	cummins swap 22.jpg
Old September 24th, 2011, 08:22 PM   #30
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Name:	cummins swap 30.jpg
ID:	83828   Click image for larger version
Name:	cummins swap 31.jpg
Old September 24th, 2011, 08:31 PM   #31
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Love the shifter. That is Badass
Old September 24th, 2011, 08:55 PM   #32
Offroadian
seasoned
I like this.
Offroadian is offline   Reply With Quote
Old September 24th, 2011, 08:58 PM   #33
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Thanks guys! I figured i would get flamed for the shifter but sometimes you just got to let your inner hotrod out. lol
Old September 24th, 2011, 09:25 PM   #34
Klumpper
Fuck Cancer!
I like what I see, and can't wait to see the finished project going down the road.
Good luck and keep us informed!
Klumpper is offline   Reply With Quote
Old September 24th, 2011, 09:34 PM   #35
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Will do. Hope to get it at least fired up in a couple weeks.
Old September 25th, 2011, 10:14 AM   #36
Fullsize4life
Kicking Cancers ASS
I take it you are keeping the ifs?
Old September 25th, 2011, 10:18 AM   #37
tator
tator's Avatar
looks sweet, got to stop by sometime soon.
tator is offline   Reply With Quote
Old September 25th, 2011, 04:30 PM   #38
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yep keeping the ifs, i want something that rides nice and sits fairly low since it will be my daily driver and haul around my blazer. I figure if it sits fairly low and doesnt have huge tires it should get better fuel mileage and will still have 4x4 for the winter.
Old September 25th, 2011, 04:31 PM   #39
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
yea stop out sometime and check it out. i saw you got a rear bumper on the dodge, do anything else to it?
Old September 25th, 2011, 06:11 PM   #40
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Shortened the rear driveshaft 4"
lengthened the front driveshaft 4"
lengthened the tcase linkage 4"
started the wiring
Name:	cummins swap 32.jpg
ID:	83841   Click image for larger version
Name:	cummins swap 33.jpg
ID:	83842   Click image for larger version
Name:	cummins swap 34.jpg
ID:	83843   Click image for larger version
Name:	cummins swap 35.jpg
ID:	83844   Click image for larger version
Name:	cummins swap 36.jpg
Page generated in 0.48029 seconds with 84 queries
