97 chevy cummins swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 14th, 2011, 09:16 PM   #1
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Default 97 chevy cummins swap
I am about half way thru a cummins swap on a 97 crew cab chevy. It was originally a 454 manual 4x4 truck. I am swapping in a 93 first gen cummins, reusing the chevy nv4500 and borg warner tcase. I switched the input shaft and retainer in the tranny and am running a 94-02 dodge clutch and bellhousing setup.
Cut the lip off the bottom of the frame right below the motor mounts and used counter sunk bolts on the top three differential case bolts.
Fits in pretty nice obviously cant use the dodge ac mount. So im using a freightliner mid mount ac bracket and compressor, and making some mounts to use the chevy alternator
I got a big intercooler from the yard and cut the tanks off and shortened the core hieght wise and fabed my own end tanks. Also had to open up the core support to fit the intercooler between the radiator and condenser. Decided to get a narrower radiator for easier intercooler plumbing and I didnt want to cut the main supports out of the core support.
Name:	cummins swap 1.jpg
ID:	83451   Click image for larger version
Name:	cummins swap 2.jpg
ID:	83452   Click image for larger version
Name:	cummins swap 3.jpg
ID:	83453   Click image for larger version
Name:	cummins swap 4.jpg
ID:	83454   Click image for larger version
Name:	cummins swap 5.jpg
Name:	cummins swap 8.jpg
ID:	83456   Click image for larger version
Name:	cummins swap 6.jpg
ID:	83457   Click image for larger version
Name:	cummins swap 7.jpg
sbcrichie is offline   Reply With Quote
Old September 14th, 2011, 09:18 PM   #2
boggin-machine
boggin-machine's Avatar
you slammed a cummins truck???? tell me it will go back up to stock and its just lowered for ease of working on it please.
Old September 14th, 2011, 09:20 PM   #3
Raymo
Square Peg
Raymo's Avatar
Send a message via AIM to Raymo
Lookin' good
Raymo is offline   Reply With Quote
Old September 14th, 2011, 09:24 PM   #4
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Lol! The borg warner tcase will hit the torsion bar crossmember so i took out the torsion bars and crossmember. You can notch the crossmember or run a different tcase but i dont see any reason to take out the one ton tcase and put in a half ton tcase behind a diesel and i want air bags any ways so it is sitting on the bump stops right now until i get the air bags fabbed up.
Old September 14th, 2011, 09:25 PM   #5
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Thanks raymo! Im guessing that chevy in you avatar has a cummins?
Old September 14th, 2011, 09:26 PM   #6
chevotass
chevotass's Avatar
hells yea. keep the pics coming. i wanted to do this to a older burban but found it easier to just buy a 7.3 excursion
Old September 14th, 2011, 09:30 PM   #7
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Will do!
Old September 14th, 2011, 09:31 PM   #8
boggin-machine
ive wanted to do this for some time to but wasnt much a write up on anything like this. im very jelous for sure!
Old September 14th, 2011, 09:34 PM   #9
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Its actually been done alot. Id like to take credit for being a trailblazer here but i cant.
Old September 14th, 2011, 09:36 PM   #10
boggin-machine
when i as looking around for sucha swap i couldnt find much detailed info on it.
Old September 14th, 2011, 10:09 PM   #11
Raymo
Square Peg
Raymo's Avatar
Affirmative. It's a never ending project, but at least I've got a solid drive train to build up from.
I've got the same engine as you, not much of a power house out of the box, but as we all know there is plenty of room for improvement
I think you'll be happy with it, and the air bags will make it awesome.
Old September 14th, 2011, 10:12 PM   #12
Raymo
Square Peg
Raymo's Avatar
Set the engine in, and the rest will fall into place
Unless you go ubervalver... then it's a shitload of work from what I've seen.
Old September 15th, 2011, 05:14 AM   #13
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Yes the simplicity of the first gen is amazing one wire to the fuel solenoid and crank to the starter and the motor will run, mechanical lift pump on the side of the block so you dont even need a electric fuel pump. From what iv heard this motor can make 280 horsepower with some pump mods and a smaller exhaust housing on the turbo. A 24 valve makes around 230 stock i beleive. I will have a little more wiring work though because i want all the stock gages to work and the cruise and ac too.
Old September 15th, 2011, 05:34 AM   #14
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
If i cant find a suitable truck to buy in the next few weeks im gonna be swapping a cummins into some thing. This is nice. A friend of mine has a 98 chevy that he has been putting a common rail into for about 5 years. It has a solid axle and all in front. But i dont think he will ever finish it.
Old September 15th, 2011, 05:39 AM   #15
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Common rail would be a whole nother animal as far as the wiring goes i would think.
Old September 15th, 2011, 06:28 AM   #16
caveman
GeoDude
caveman's Avatar
more pics more pics more pics
Old September 15th, 2011, 06:25 PM   #17
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Pics? If you live in sturgis you can just come out and see it!
Old September 15th, 2011, 09:58 PM   #18
Strangler
Strangler's Avatar
Very, very cool.
Old September 16th, 2011, 07:44 PM   #19
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Some more pics. Didnt get much done today just the manifold on and torqued, turbo on, looked at down pipe a little, ac pump on and checked for belt length, and got a 95 accumulator filter to look at down pipe clearance.
Name:	cummins swap 11.jpg
ID:	83543   Click image for larger version
Name:	cummins swap 12.jpg
ID:	83544   Click image for larger version
Name:	cummins swap 13.jpg
ID:	83545   Click image for larger version
Name:	cummins swap 14.jpg
ID:	83546   Click image for larger version
Name:	cummins swap 15.jpg
Old September 16th, 2011, 08:05 PM   #20
Dazz
Dazz's Avatar
Send a message via MSN to Dazz Send a message via Skype™ to Dazz
Dayum
Dazz is offline   Reply With Quote
Page generated in 0.32917 seconds with 84 queries
