Identify this 4 speed transmission - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 14th, 2011, 06:37 PM   #1
pyrowaves
The Boss
pyrowaves's Avatar
Send a message via AIM to pyrowaves
Default Identify this 4 speed transmission
Quick looking at it and some searching I thought saginaw.
I'm not 100% sure. I need to rebuild it and I want to get as much info about it as i can before I start. I don't have it in my possession yet as I will be doing this for a friend and I haven't had time to get over there. He took it out and took these shots of it. It was behind a small block chevy.
Any other info you might have would be appreciated also. As well as where to find parts.
pyrowaves is offline   Reply With Quote
Old September 14th, 2011, 06:54 PM   #2
deerebowtie
Unchained
deerebowtie's Avatar
if it was in the original car, I'm going to guess its an M-20. 7 bolt side cover, need to see a better shot of the tail housing to be sure.
Old September 14th, 2011, 06:58 PM   #3
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I'll call it "Eric".
@clarkstoncracker
Old September 14th, 2011, 07:01 PM   #4
pyrowaves
The Boss
pyrowaves's Avatar
it was not original in the car. so I only have the trans to go by. I'll try to get better pictures.
Old September 14th, 2011, 07:02 PM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
http://www.camaros.org/forum/index.p...ge;topic=872.0
@clarkstoncracker
Old September 14th, 2011, 07:10 PM   #6
joe_jeep
welfare wheeler
joe_jeep's Avatar
looks like saginaw to me? i googled the bell housing casting number. it was oe for a 78 to 81 a/g body with a sagianw. they could have used it for other stuff too though.
if its a swap it could be nearly anything.
i thought muncie trannys had the shifter bolted to the top of the trans, but i could be wrong.
i thought super t10's had the shifter mounted on the tail housing, but i still could be wrong.
Old September 14th, 2011, 07:16 PM   #7
thinking Saginaw 4 speed, since reverse is in the side cover, not the tailhousing.
http://www.yearone.com/updatedsingle...nfo/muncie.asp
please help me ID my saginaw 4 speed... - THE H.A.M.B.
Old September 14th, 2011, 07:51 PM   #8
Red68Camaro
End nerd persecution
Red68Camaro's Avatar
I agree.....If it was a 67-69 Muncie there would be a part number that starts with "P".
Red68Camaro is offline   Reply With Quote
Old September 15th, 2011, 08:16 PM   #9
littletrucker
I'd hit that
littletrucker's Avatar
Looks like a Saginaw 4 speed, the Saginaw have the 7 bolt side cover same (slightly diffrent shape) as a muncie, but the muncie has reverse is on the tail housing..
The saginaw should be a cast housing and the muncie is aluminum
Old September 15th, 2011, 08:37 PM   #10
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
That ugly ass plate on the side was for the "third arm on the GM Monzas and Vegas back in the old days. Camero didn't start using that till 82.
another thing if it was a very early case it would have the reverse lever in the tail housing and the speedo would go out the right side.
Yetti
Page generated in 0.20754 seconds with 54 queries
