D30 wheel hub - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 13th, 2011, 06:55 AM   #1
Immortal
NO RELIGION WAT!
Immortal's Avatar
Default D30 wheel hub
Can they be bad, but not exhibit any issues upon inspection? When I bank left on the freeway my vibrations seem to fade away, but once I straighten out it is back to vibrating!
Old September 13th, 2011, 07:18 AM   #2
Yes they can. They can be a pain to diagnose which side too.
Old September 13th, 2011, 07:27 AM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
X7.57
H.o.r.e
Old September 13th, 2011, 09:42 AM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Where do you feel the vibration?
What about when you bank right?
Old September 13th, 2011, 09:43 AM   #5
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
Yes they can
Old September 13th, 2011, 09:46 AM   #6
Immortal
NO RELIGION WAT!
Immortal's Avatar
Hmmmmmm..........
Seems like all the vibration is coming from drivers side front. Banking left is the only time the vibrations lessen up. Banking right is the same. It is a horrible vibration too. Something you would think would be evident upon inspection.
Old September 13th, 2011, 12:41 PM   #7
junk90xj
ALLPRO AUTO
junk90xj's Avatar
typical of a bad wheel bearing
http://www.apalansing.com/
Old September 13th, 2011, 12:51 PM   #8
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Hmmmmmm..........
Had same thing happen to me before.
*2007 Rubicon
*2006 Duramax
*2010 TDI
*2005 CRD
Old September 13th, 2011, 01:00 PM   #9
Remove the short stub shaft and see if it changes.
No, don't really do that. It could end up bad
Old September 13th, 2011, 03:43 PM   #10
Immortal
NO RELIGION WAT!
Immortal's Avatar
2wd Don't go hitting me with a fish again ahole!
Old September 14th, 2011, 08:40 AM   #11
Immortal
NO RELIGION WAT!
Immortal's Avatar
Driverside replaced.....no change.....:-(
Old September 14th, 2011, 12:48 PM   #12
Jeeperz Creeperz
GL 4x4 Vendors
Hmmmmmm..........
What I meant was do you feel it in the steering wheel or the seat of your pants.
Old September 14th, 2011, 12:56 PM   #13
kickstand
circling the drain
kickstand's Avatar
is the ujoint bad on that side? tire warn uneven?
Old September 14th, 2011, 01:21 PM   #14
Bones
Bones's Avatar
simple allignment issues can do that too
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old September 14th, 2011, 01:58 PM   #15
Jeeperz Creeperz
GL 4x4 Vendors
X2
Plus tire wear (caused by bad alignment).
Old September 15th, 2011, 09:14 AM   #16
Immortal
NO RELIGION WAT!
Immortal's Avatar
Both.....going to replace the passenger side today. If the vibrations are still there I will have a Tranny Tom take a look at my transmission as a possible source.....
Old September 15th, 2011, 09:15 AM   #17
Immortal
NO RELIGION WAT!
Immortal's Avatar
All good I had crane alignment do mine......twice!
Old September 15th, 2011, 09:18 AM   #18
Immortal
NO RELIGION WAT!
Immortal's Avatar
X2
Tires show even wear
Old September 15th, 2011, 10:38 AM   #19
mrclean
Silver Lake
mrclean's Avatar
to the u-joint comment
mrclean is offline   Reply With Quote
Old September 16th, 2011, 12:17 PM   #20
hotwired
If the unit bearing is bad and you remove the stub shaft, the bearing could seperate while your driving. Would not be good at speed.
hotwired is offline   Reply With Quote
Page generated in 0.32274 seconds with 83 queries
