Ox Adjustment - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 12th, 2011, 07:53 PM   #1
mschaffer66
mschaffer66's Avatar
Default Ox Adjustment
Ok, so this Ox is driving me a bit nuts.
I've been trying to adjust the cable, but i have to crank down the shifter end to the point where its almost near impossible to force the shifter to the engaged detent before it locks in. If I adjust the cable or shifter out a just a hair it doesn't engage.
Anyone else have experience with these things?
Old September 12th, 2011, 08:02 PM   #2
deerebowtie
Unchained
deerebowtie's Avatar
I'd suggest tech, but its easier to pay someone else to do it as I recall.
Old September 12th, 2011, 10:32 PM   #3
Jesse
Jesse's Avatar
I don't have any problems with mine. Are you sure the cable is set properly on the axle side? It sounds like it's off or your cable is messed up.
Jesse is offline   Reply With Quote
Old September 12th, 2011, 10:46 PM   #4
MSUjeeper
MSUjeeper's Avatar
I've been having the same problem with mine. It worked fine and now it won't engage. Might just pay to have someone do it cuz it's driving me crazy.
MSUjeeper is offline   Reply With Quote
Old September 13th, 2011, 06:50 AM   #5
mschaffer66
Will it just not engage, or does it feel like you are going to break the handle off the shifter to get it to set in the detent?
If it just won't engage that might be an easy fix with cable adjustment.
I'm seriously considering a spool or a detroit and let someone else who likes to dick with this stuff get a good deal on a used Ox :)
Old September 13th, 2011, 07:10 AM   #6
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
Stupid question, but are you driving when you are trying to put it in?
Mulely is offline   Reply With Quote
Old September 13th, 2011, 07:15 AM   #7
mschaffer66
Not driving, but jacked up rotating the wheels.
Thats what the few write ups I read about adjusting the cables said to do.
Old September 13th, 2011, 08:28 PM   #8
Mulely
Mulely's Avatar
That's how I do mine too. It's been forever since I've had to adjust mine but is there a cable adjustment at the bell housing where it screws into the cover along with the handle adjustment?
Old September 15th, 2011, 05:45 PM   #9
John D
John D's Avatar
Tried this?
http://www.ox-usa.com/ox/Instruction...6/Default.aspx
Just click the cable adjustment link.
I have had two and when I followed the factory instructions I never had an issue. Good luck!
Old September 15th, 2011, 07:19 PM   #10
mschaffer66
I fucked with it tonight. I think the thing that slides the shift fork back and forth wasn't fully threaded into the shift fork. I think it works now
Either way it locks...which is the important part for me :) lol
Page generated in 0.23375 seconds with 53 queries
