Driveshift Balancing Required - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 11th, 2011, 03:45 PM   #1
orangebronco
1976Bronco
orangebronco's Avatar
Default Driveshift Balancing Required
I'm looking for someone that does driveshaft balancing on the side somewhere in the Waterford / Clarkston area. I had my shaft lengthen (it was fun) and supposedly balanced but now I'm chewing up U-joints.
Thanks for any info
Tony
orangebronco is offline   Reply With Quote
Old September 11th, 2011, 03:53 PM   #2
deerebowtie
Unchained
deerebowtie's Avatar
not interested in spin balancing?
Old September 11th, 2011, 05:22 PM   #3
orangebronco
1976Bronco
I'm not quite following your question, but I'm assuming that how it should be balanced, by the means of a lath or some other spining device. let me know your thoughts please.
Old September 11th, 2011, 05:30 PM   #4
s10v8zach
JACK STAND WHEELER
s10v8zach's Avatar
I build. All my own driveshafts for offroad use and all I do for balancing is drill a hole at the top of the tube and pour 3/4 of a quart of trans fluid in it then weld the hole up. I've had mine up to 70 with no. Vibs and have not broke or wore out a u joint since built. That was in january I wheel about twice a month if not more. Just my .02 good luck
s10v8zach is offline   Reply With Quote
Old September 12th, 2011, 09:43 PM   #5
deerebowtie
Unchained
what zach said, works just dandy fine. just make sure to keep your joints in phase.
Old September 12th, 2011, 10:35 PM   #6
Immortal
NO RELIGION WAT!
Immortal's Avatar
Great to know!
Old September 13th, 2011, 08:36 AM   #7
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
I'm gonna have to try that!!
Old September 13th, 2011, 08:45 AM   #8
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
i also do the fluid trick
Old September 13th, 2011, 01:06 PM   #9
mudbillyredneck
mudbillyredneck's Avatar
How do you determind the rocket science behind how much fluid to use ??
Is there a general rule of thumb for fluid used Vs tube lenght or dia ??
mudbillyredneck is offline   Reply With Quote
Old September 13th, 2011, 04:46 PM   #10
orangebronco
1976Bronco
Ok thanks for the info, I found out that Clydes in Waterford/Pontiac does high speed balancing for around $85.00
Old September 13th, 2011, 09:21 PM   #11
deerebowtie
Unchained
you may want to check your pinion angle too
Old September 13th, 2011, 09:54 PM   #12
littletrucker
I'd hit that
littletrucker's Avatar
how did you lengthen the shaft? sounds like you did it yourself?
Old September 14th, 2011, 08:00 PM   #13
orangebronco
1976Bronco
The long story is, a contractor at my work told me that driveshaft fabrication was he side job and have been doing it for 15 years. To give him credit, he does seem to know what he's talking about. The only problem is he's no longer at my work and lives downriver. Now he measured the driveshaft out in the parking lot at work and then the next day I brought the shift to work for him to take home. On a Saturday I went to install it but it was to long. He drove from downriver to Waterford, picked it up and went back home. He made the adjustment and drove it back all in the same day. I think he probably skip the second balancing. So I was looking for someone local to do the balancing so I didn't have to drive it downriver. Sorry, more information then you properly asking for.
Old September 16th, 2011, 12:11 PM   #14
BOGDOG
BOGDOG's Avatar
I saw your truck somewhere around White Lake/Waterford last weekend it doesn't look to much higher than my 73 and I have been able to run the stock shaft. On my 77 I moved the axle back and just orderd a shaft from Tom Woods. Nice Bronco BTW.
Old September 17th, 2011, 11:00 AM   #15
orangebronco
1976Bronco
I have a 5.5 lift and was able to run the stock driveshafts but 1-2" of the splines was showing. So for offloading reasons I had them lengthen. Thank for the compliment and if you see me around town stop me and we'll talk Bronco's .
Page generated in 0.26828 seconds with 68 queries
