Thread Tools
Old September 11th, 2011, 01:49 PM   #1
bitchofanxj
Are you cooool maaaann?
bitchofanxj's Avatar
Talking Exo XMJ (WTF was I thinking?)
Got some tires mounted up to see how its going to sit. The front is on some short ass jack stands right now so the rear will settle down some when the weight is even. Rear bumper tacked, plated 12" of the frame so I had something to weld to. I'll be adding a 2" receiver to the bottom of the bumper. Still have a crap ton of work to do.
bitchofanxj is offline   Reply With Quote
Old September 11th, 2011, 01:56 PM   #2
Hi Im Adam
Bitch'n
Hi Im Adam is offline   Reply With Quote
Old September 11th, 2011, 02:07 PM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Rock out
H.o.r.e
cheap gears [url]www.ronsmachiningservice.net[url]
Old September 11th, 2011, 02:25 PM   #4
HVYRTFT
Reed my teef
HVYRTFT's Avatar
I remember when we used to wheel that thing!
Old September 11th, 2011, 02:53 PM   #5
XJcoupe
1ton XJ
XJcoupe's Avatar
subscribed- like to see how it turns out, funny how life gets busy just before/after you get married. Im kinda in same boat, my XJ still waiting to be finished after popping the Big Q. Now I only got 20 days left till the big day, then Im moving out to the garage, she can have the house I told her, haha
Old October 15th, 2011, 09:30 AM   #6
bitchofanxj
Slow progress
Old October 15th, 2011, 10:31 AM   #7
dmoney
tj on 36 iroks
dmoney's Avatar
Location: fremont michigan about hour north of grand rapids
Fuck'n sweet love the tailgate.....
dmoney is offline   Reply With Quote
Old October 15th, 2011, 04:13 PM   #8
XJcoupe
1ton XJ
XJcoupe's Avatar
when your done, will it still be road worthy, or just offroad ?
Old May 25th, 2012, 03:51 PM   #9
bitchofanxj
Small update, my steering is pretty much set up. Need to make some double sheer brackets and a spacer for the knuckle end of the drag link and it's all set. I've got WJ knuckles, 3/4-16 heims, 1-1/8" solid stock for links. I like the WJ style steering better than the stock style and the WJ brakes should work a lot better too.
Looks great turned to the pass side.
Hits on the pass leaf when turned to drive side. I'm going to make a spacer to go between the heim and knuckle and it should take care of the issue. I'm thinking 1" or less should do the trick.
Bumper is fully welded to the frame now. I didn't want a few bolts being the only thing holding it to the frame with the shackle mounts on the front now. It was a lot of tedious welding but I like doing a lot of smaller plug welds, seems to me that its stronger than the large holes that some people do with hole saws. More surface area covered I guess, my 2cents. I'll be adding a little more plate to the front uni-rails so nothing gets tweaked. Still have a lot to do, hoping I can have it done by fall now that I have my own garage to work on it in.
I had the shackles laying around from a long gone YJ project but I'm thinking that some aftermarket XJ shackles would have been a lot easier to set up. Oh well, they work. I made the shackle mounts my self and HVYRTFT helped me drill and tap the steering links at the shop he works at.
Old May 25th, 2012, 04:16 PM   #10
boggin-machine
boggin-machine's Avatar
Looks like it will be cool when done
08 qcsb Duramax Ltz
02 tj with some parts laying around **for sale**
08 crf 450 with a few goodies
Old June 14th, 2012, 07:16 PM   #11
bitchofanxj
The tail gate I had ended up being a little more rotted out than I originally thought. I ended up just using the outer skin. I didn't really want to screw around with rigging it up to work when it's going to be mainly a trail rig anyway. Still picking away at it.
Old June 14th, 2012, 09:06 PM   #12
Ford forever
Bought another jeep
Ford forever's Avatar
Nice work!!! Where in n. Muskegon you at?
Ford forever is offline   Reply With Quote
Old June 14th, 2012, 09:18 PM   #13
bitchofanxj
Actually in Fruitport now, thanks for reminding me to change that.
Old June 14th, 2012, 09:20 PM   #14
CAMO MAN
CAMO MAN
CAMO MAN's Avatar
Bad ass build, looks awsome, love the look of the rear. Keep up the good work
CAMO MAN is offline   Reply With Quote
Old June 25th, 2012, 05:47 PM   #15
curbdog17
Door Alignment Specialist
curbdog17's Avatar
Good looking back side
Bare Bones Offroad
Old June 26th, 2012, 07:13 AM   #16
Offroadian
seasoned
Nice.
Offroadian is offline   Reply With Quote
Old August 12th, 2012, 11:08 AM   #17
bitchofanxj
Uh oh! Doubler!
I'm so fucking ADD, I never get one thing done on this jeep before I start another!
Cut up this. Plate is just 1/4" steel, just need to bore it and add the bolt pattern for the other 231and weld up the numinum.
Modified this, turning it down sucked but milling the splines was a lot easier than I thought it would be. Just very time consuming.
Old August 15th, 2012, 11:42 PM   #18
bitchofanxj
Started the clearance hole with a 4.5" hole saw. I''ll get it closer later, just need to figure out how far I need to clock the bolt pattern before I drill any mounting holes. Shooting for as flat as possible on the underside.
Old August 16th, 2012, 12:44 AM   #19
MiNi Beast
Imakesensitivepeoplecry!!
MiNi Beast's Avatar
Send a message via Yahoo to MiNi Beast
looking good man, hope to see you finish it and wheel it and not just keep doing shit then to sell it when you almost able to take it out like some other creepy guys I know.
Old August 16th, 2012, 06:26 AM   #20
curbdog17
curbdog17's Avatar
Originally Posted by mini beast View Post
looking good man, hope to see you finish it and wheel it and not just keep doing shit then to sell it when you almost able to take it out like some other creepy guys i know.
zing!!
Bare Bones Offroad
Thread Tools
Copyright ©2005 - 2012 Cracker Enterprises - Powered by Linux
Page generated in 0.20887 seconds with 50 queries
