Painting stuff - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 9th, 2011, 03:17 PM   #1
shawn
Resident HVAC/R Jambi
shawn's Avatar
Default Painting stuff
My front bumber needs a new paint job, bad!
I'm not all that hip to powder coating. So I'm looking for a good durable/hard/long lasting paint to use after I get it stripped down.
Also want to paint my rims black. Like a flat black. And these are aluminum. Looking for the same thing, maybe the same paint for both?
Any opinions?
Old September 9th, 2011, 03:50 PM   #2
BRONCBUSTER
BRONCBUSTER's Avatar
Not a fan of powder coat either!!!!
I have had good luck with a good self etching primer and automotive paint
With hardener added.
Just let your paint supply dealer know what you are going to paint.
Good luck
BRONCBUSTER is offline   Reply With Quote
Old September 9th, 2011, 04:09 PM   #3
68Scout
'68 Scout ~rebuilding
68Scout's Avatar
Valspar tractor and implement paint + enamel hardener from TSC. Cheap and durable. I use it on frames, axles, trailers, etc. and it holds up great.
-Justin
68Scout is offline   Reply With Quote
Old September 9th, 2011, 04:16 PM   #4
Hunter9
Not Right!
Hunter9's Avatar
Look for Chassis Saver, stuff is Bulletproof and requires no primer. Comes in black, flat black and aluminum, might be other colors too.
Have used it on everything from frames, to wheels to a trailer. Stuff rocks.
Just wear gloves cause it will not come off your skin for a long time!
Hunter9 is offline   Reply With Quote
Old September 9th, 2011, 05:26 PM   #5
kb8ymf
Not as old as Whiterhino
kb8ymf's Avatar
On steel, Etching Primer and Rustoleum Hammered. Been on the Tracker for years. Easy to touch up.
On Aluminum, good luck getting it clean enough and getting the paint to stick.
The paint guys here can probably reccommend a primer tht might work but I've never had much luck with alum.
jim-kb8ymf
kb8ymf is offline   Reply With Quote
Old September 9th, 2011, 07:20 PM   #6
Tizken
Can you get the rims anadoized? I had some shocks on a RC car that looked pretty cool with a black hard coat of some sort.
Tizken is offline   Reply With Quote
Old September 9th, 2011, 07:24 PM   #7
Swampdog02
Wakley Creek Wacos!
Swampdog02's Avatar
X2 This stuff has been on my Jeep frame & bumpers for 4+ years now and it still looks great. You won't be sorry.
http://www.magnetpaints.com/underbody.asp
Swampdog02 is offline   Reply With Quote
Old September 9th, 2011, 07:30 PM   #8
My only experience with powder coat was not successful. Paint only seems to stick to aluminum where I don't want it.
Was I any help? LOL
Old September 9th, 2011, 08:15 PM   #9
Windsorf350
Rusty Racing
Windsorf350's Avatar
i had been looking into tuff paint and ive got my mind set on por15... its supposed to be some tuff stuff
Windsorf350 is offline   Reply With Quote
Old September 9th, 2011, 09:03 PM   #10
bdd1469
bdd
bdd1469's Avatar
For paint to work on aluminum it will need to be media blasted.
All the other recomondations are good for the bumper,it depends what you want to spend.
Old September 9th, 2011, 10:05 PM   #11
joe_jeep
welfare wheeler
joe_jeep's Avatar
i just finished a front bumper for my wifes jeep. i was in a pinch for time and was looking for a "paint" to apply. i ended up with rustoleum truck bed liner. its not really a bed liner. its like a textured paint.
its really thin, multiple coats do not build to a bedliner thickness. i was not impressed with it. i do like the texture though. if it holds up for a while(im betting it wont)i will be happy. i used duplicolor bed liner on my old tj's bumper it looked great for a couple months. have you thought of some implement paint from tractor supply? an oil based enamel for equipment could work i bet. its super thick and takes forever to dry though. how is the boat trailer holding up? its an oil based enamel. it was pretty rusty b4 i painted it. i knocked off the loose stuff, and brushed it. it looked good last time i saw it.
what ever paint you use get some hardner, it makes a big difference.
joe_jeep is online now   Reply With Quote
Old September 11th, 2011, 04:17 PM   #12
shawn
shawn's Avatar
I want a Sattin finish, especially on the rims. I like the idea of chassis saver, but not sure how it would look sprayed on, if it would have a nice smooth sattin look to it.
Old September 11th, 2011, 04:20 PM   #13
shawn
shawn's Avatar
And I've been reading that I really need strip it well and use a good etching primer. In fact, if I use a good enough primer (like the green etching stuff) that I might even get a way with a rustoleum spray paint.
All of my stuff on my last Jeep I made, and I got some industrial green etching primer, and 6-7 years later, my cheap black paint was still holding up well. Maybe this is the thing to do again. I was just winging it before.
Old September 11th, 2011, 04:25 PM   #14
300Grand
300Grand's Avatar
DP-90 epoxy primer, it's satin black and holds up like nothing else.
300Grand is offline   Reply With Quote
Old September 11th, 2011, 04:29 PM   #15
DuffMan
Your Message Here
DuffMan's Avatar
x2 on Rustoleum Hammered - I use it on my bumpers, tire rack, etc... and it holds up well and it easy to touch up/fix. Texture & finish cover up mistakes and fixes well.
I did my rocker guards with POR-15 covered with rattle can bedliner. Tough and easily fixable.
POR-15 is tough, but fussy and unforgiving on surface prep and application. Eastwood Rust Encapsulator is similarly good and less fussy.
Old September 12th, 2011, 03:26 PM   #16
shawn
shawn's Avatar
I'll look into this, thanks.
Old September 12th, 2011, 07:34 PM   #17
danimal
IS IT JEEPIN TIME
danimal's Avatar
Dp90 is not an etching primer it will need to be sealed by mixing it with proper reducer
Transtar makes a nice etching primer in a spaybomb that will work on aluminum and steel however for best results I would sand blast the rims and the bumpers and make sure to use a wax and grease remover just before spraying
You can then top coat it with rustoleum spraybomb
I also like the chassis saver but you should still sandblast parts first I have had it peal before from poor prep work
Sent from my LS670 using Tapatalk
danimal is offline   Reply With Quote
Old September 12th, 2011, 07:55 PM   #18
danimal
IS IT JEEPIN TIME
danimal's Avatar
If you want 2 stage durabilty and dont mind spending the money PPG has a clear thats been out for a couple of years now that gives a very flat smooth look that is easy to spray and tough as hell
Old September 13th, 2011, 12:45 PM   #19
joe_jeep
welfare wheeler
joe_jeep's Avatar
danimal is correct. the transtar stuff is great. kinda pricey, but it works.
Old September 13th, 2011, 01:09 PM   #20
cruzer72
cruzer72's Avatar
Sandblast, proper prep, DP90, and top with one those listed below
Dp90 is an epoxy it will fade in sun and you do not need to etch prime.
Kirker hotrod black (single stage)
SEM Hotrod black (single stage)
SEM Trim black(Enamel??)
Hotrod Flatz (simgle stage) Supposedly PPG Omni with flattener
Sikkens Ralley black (single stage)
Dupont Hot Hues (single stage)
John Deer Blitz black. (Implement paint)
2015 Wrangler Unlimited
1985 S-Blazer 4 linked, 427ci
1963 Nova SS 350hp I6
1972 Monte Carlo
1993 Tracker 4:1 Case, 33" KM2
cruzer72 is offline   Reply With Quote
Page generated in 0.44927 seconds with 83 queries
