dodge straus oil leak... help!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 9th, 2011, 01:10 AM   #1
jessezipper
Default dodge straus oil leak... help!!
my brother has a 99 stratus 2.4 dohc . and he swears its leaking oil from the oil filter adapter arm ( theres a small crack in it). he tells me its part of the engine and the adapter arm doesnt unbolt. is there a simple cheap fix ???
jessezipper is offline   Reply With Quote
Old September 9th, 2011, 04:12 PM   #2
chriszildjian17
chriszildjian17's Avatar
actually that arm does come off. ITs part of the oil pump. the chrysler part number is 4694304. They around 700 new. your best bet is to see if you can get one aftermarket for cheap. or even a junk yard. You will have to pull the motor away from the tranny to change this out.
chriszildjian17 is offline   Reply With Quote
Old September 9th, 2011, 04:14 PM   #3
chriszildjian17
just ask for an oil pump
Old September 10th, 2011, 09:45 AM   #4
jessezipper
im goin over there today, ill have to take a look at it thanks
Old September 10th, 2011, 09:48 AM   #5
jessezipper
advanced auto sells em for 236. are they hard to replace??? once i pull the motor away from the traqnny is it all straight forward???
Old September 16th, 2011, 09:47 AM   #6
chriszildjian17
=yup, not bad to do at all. the hardest thing is pulling the motor up.
Page generated in 0.24583 seconds with 41 queries
