Pinion bearing replacement on F150 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 8th, 2011, 08:44 PM   #1
awalters
Hired Badass
awalters's Avatar
Default Pinion bearing replacement on F150
My buddy wants to replace a pinion bearing on his truck. The gears are ok just the bearing is going. My question is since the gears are remaining the same, and the housing is remaining the same, would we be able to get away with just reusing the shims that are currently there?
awalters is offline   Reply With Quote
Old September 9th, 2011, 12:49 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
You should be able to because that's what it was set up with. And there should only be 1 shim under the inner pinion bearing. You will need a new crush sleeve.
Page generated in 0.16925 seconds with 29 queries
