7.3 runs like crap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 8th, 2011, 07:07 AM   #1
crassell
crassell's Avatar
Default 7.3 runs like crap
1995 7.3, E40d, 5.13 gears. All stock. Iíve had the truck for couple years, but just this week got it on the road.
Truck runs like crap, starts hard, has no power. Canít figure out why.
Both fuel tanks are new, all new fuel lines. Fuel filter. Cam sensor. Glow plugs. New back pressure sensor. Acts like the turbo is not working. Very sluggish to accelerate.
I'm comparing this to other diesels Iíve had in the past; 88 f350, 90 F250, 1996 K2500. All of these would outperform the 95.
Suggestions? Ideas?
crassell is offline   Reply With Quote
Old September 8th, 2011, 07:35 AM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Sounds like the back pressure valve is stuck closed.
@clarkstoncracker
Old September 8th, 2011, 07:43 AM   #3
X2, I hate that damn valve. Some day I'll delete it.
Old September 25th, 2011, 03:38 PM   #4
Hoofinit
Hoofinit's Avatar
Have you checked the air filter?
Hoofinit is offline   Reply With Quote
Old October 16th, 2011, 08:37 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i know this is an old post but did you ever figure it out? guy i work with has a 94 F350 diesel with very similar issues. i haven't looked at it yet but i'm curious as to a direction i should look first.
Old October 16th, 2011, 10:07 PM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
does it blow white smoke? clogged cat/particle filter? check fuel pressure? Bad injectors? does it idle ok?
Old October 18th, 2011, 05:55 PM   #7
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
It was the EBPV or sensor, I forget.
@clarkstoncracker
Old November 29th, 2011, 12:15 PM   #8
orionn
orionn's Avatar
The place working on mine had a simular problem with a Dodge.....It had a mouse nest in the intake all the way to the Turbo.............
orionn is offline   Reply With Quote
Old December 21st, 2011, 10:55 PM   #9
pkupman82
Might sound crazy but check the engine oil level. The 7.3 PSDs had oil fired injectors. For those of you who don't know the injectors on a PSD are fed oil by a high pressure oil pump. When the oil pressure reaches the needed psi it will "pop" the injectors feeding the engine fuel. It's possible the oil level is low enough that the high pressure oil pump can't provide enough pressure to properly fire the injectors. I know this because it happened to a buddy of mine, the engine oil level got low enough to the point to where the truck wouldn't even run. As soon as he topped it off it ran like a champ. I could be wrong but it's something simple and easy to check. Hard starting probably is due to bad glowplugs.
pkupman82 is offline   Reply With Quote
Old January 7th, 2012, 05:38 PM   #10
special k
special k's Avatar
hard start could be a glow plug problem(relay, glow plugs themselves, under valve cover harness as well)
Page generated in 0.19518 seconds with 53 queries
