TJ Wrangler Stetched Very Nice Build 9000.00 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 7th, 2011, 07:00 PM   #1
Rubilooe
Rubilooe's Avatar
Default TJ Wrangler Stetched Very Nice Build 9000.00
1999 Jeep Wrangler TJ Stretch to 103 Rock Crawler
Boat Sides with Full Belly Skid all items are built to be removed without removing suspension or drive train items
Front and rear bumpers are added to the tube fenders and roll cage all tie together for a very strong and safe rollover protection four point lap and shoulder harness seat belts the seats have been upgraded the fuel system is relocated up and out of the way for ground clearance as well as the exhaust.
Front axle is a custom built Ford Nine Inch with alloy axles CTM U Joints tube seals 4.88 Gears Detroit Locker all outer item are upgraded to 5 on 5.5 bolt pattern with Warn lockouts (has a spare lockout included) Rear axle is a Dutchman Motor sport built Dana 44 with Alloy axles Riddler cover Detroit Locker and 4.88 Gears. Suspension is a custom built 3 link front and triangulated 4 link rear using Bilstien Remote Reservoir 7100 series 14 travel shocks and Rubicon Express 4.5 Coil springs Currie Antirock Front and Rear Sway bars as well as Currie steering components Tires are 37 Goodyear MTRs that have been custom grooved mounted on Allied 32 bolt bead locks. Engine is 4.0 with a aftermarket camshaft Transmission is a Automatic with a upgraded valve body 231 Transfer Case with wider chain lower gears and slip yoke conversion with Tom Woods drive shafts Novak Shifter.I am sure I have left out many things .
9000.00 Cash
The list is very long and this rig is built very strong
KDN KUSTOMS
Rubilooe is offline   Reply With Quote
Page generated in 0.17326 seconds with 26 queries
