turning radius - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 7th, 2011, 10:43 AM   #1
GMKLR50
Broke wheeler
GMKLR50's Avatar
Default turning radius
Anyone have any good way to get a tighter turning radius out of a 10 bolt front axle?
I have cross over steering, the wheels go lock to lock.......I just have to make like 200pt turns on the trail....anyone have any ideas?
I thought K5's has a narrow rear track to help with turning but thats not an option for me really
are there any tricks?
GMKLR50 is offline   Reply With Quote
Old September 7th, 2011, 11:12 AM   #2
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
If you have a twin-stick case and not a spooled rear, add a cutting brake and front dig your turns.
JohnnyJ is online now   Reply With Quote
Old September 7th, 2011, 12:00 PM   #3
GMKLR50
Broke wheeler
GMKLR50's Avatar
detroit rear, spool front ( to be changed ) no twin stick (np208) no cutting brake
Old September 7th, 2011, 03:38 PM   #4
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Take that out and see how it turns....
Old September 7th, 2011, 03:47 PM   #5
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
This
Old September 7th, 2011, 05:29 PM   #6
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Try this
Getting the most out of stock Power Steering - Great Lakes 4x4. The largest offroad forum in the Midwest
I’m spooled front and lunch boxed rear so I feel for ya. I haven’t wheeled it yet but it should definitely help.
Old September 7th, 2011, 05:37 PM   #7
Trail Junkie
iamfawkinwithyou
Lunch box rear will ratchet and let you steer better than welded/spooled
Old September 7th, 2011, 05:59 PM   #8
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I was curious when I saw the thread right up to "spooled front". it explains a lot. My K5's all did great mud or snow for tight turns. another thing to look at after you take out the spooled front might be tire size? smaller tires will make it turn tighter also
Yetti
Old September 7th, 2011, 09:30 PM   #9
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
he has a detroit rear
Old September 7th, 2011, 09:33 PM   #10
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Also if you have selectable hubs you can 3 wheel to get lined up, and then lock in the other hub once youre ready.
Old September 7th, 2011, 09:35 PM   #11
Trail Junkie
iamfawkinwithyou
Wadey I ment you will turn easier, cause u have a rear lunch box
Old September 7th, 2011, 09:44 PM   #12
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
But his detroit should turn just as easy or better right?
Old September 7th, 2011, 09:46 PM   #13
Trail Junkie
iamfawkinwithyou
No, it don't ratchet
Old September 7th, 2011, 10:23 PM   #14
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
hmm didn't know that
Old September 8th, 2011, 07:19 AM   #15
GMKLR50
Broke wheeler
GMKLR50's Avatar
In 2wd and 4wd it goes lock to lock, the spool just makes it a pain in the ass in 4wd to get there but it will go with a little movement.... I have been thinking of getting skinner tires but mine are like new and dont want to loose out getting rid of them (I would need ne rims too). I have no problem turning the tires on everything execpt when jamed up next to rocks....
Old September 8th, 2011, 07:30 AM   #16
Trail Junkie
iamfawkinwithyou
Put a lock right in the ft. I have one with my rear welded, fullsize4life is welded both ends, on the same trails I get threw with ease, he dose 10 pt turns like you. We both have jeeps and his wheel base is about 6" shorter which should help him. IMO its your spooled ft causing your prob
Old September 8th, 2011, 07:51 AM   #17
GMKLR50
Broke wheeler
GMKLR50's Avatar
i am planing on changing out the spool...lock rite keeps coming up as a great option but will it lock up when I need it while the wheels are turned in rocks and such?
Old September 8th, 2011, 07:56 AM   #18
Trail Junkie
iamfawkinwithyou
Search my name on youtube, the white jeep has a lockrite in the ft and has never not locked when needed.
Page generated in 0.43038 seconds with 78 queries
