Differential Cover Drip - Gasket vs. RTV (or both) - Great Lakes 4x4. The largest offroad forum in the Midwest
View Poll Results: How to seal a differential cover
Gasket 2 8.33%
RTV 18 75.00%
Both 4 16.67%
Voters: 24. You may not vote on this poll
Old September 6th, 2011, 05:58 PM   #1
MagMan68Classic
Default Differential Cover Drip - Gasket vs. RTV (or both)
My rear differential cover is dripping (D35) on my '93 Wrangler
I'm wondering what I should use to seal it
I've seen posts about how RTV works fine, but a gasket is the right way to do it
I'm just looking for some advice, maybe based on prior experience or knowledge
Thanks
Gasket I'm considering
http://www.quadratec.com/products/52416_103.htm
MagMan68Classic is offline   Reply With Quote
Old September 6th, 2011, 06:06 PM   #2
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Always used rtv and I have never had one leak.
Old September 6th, 2011, 06:19 PM   #3
Fraser
Fraser's Avatar
I've started using gaskets b/c i don't feel like dealing w/ the mess. (lazy)
Old September 6th, 2011, 07:12 PM   #4
littletrucker
I'd hit that
littletrucker's Avatar
Ive been using rtv.. Works great!
Old September 6th, 2011, 07:19 PM   #5
Shotgun
I only wheel with boats.
Shotgun's Avatar
Whats a diff cover?
RTV?
I'm so confused.
Old September 6th, 2011, 07:20 PM   #6
Shotgun
Shotgun's Avatar
I've always used RTV also.
Old September 6th, 2011, 07:23 PM   #7
@_'-'
delete
@_'-' is offline   Reply With Quote
Old September 6th, 2011, 07:23 PM   #8
03tjsport
Red Dragons!
03tjsport's Avatar
RTV only. Works great from the factory.
03tjsport is offline   Reply With Quote
Old September 6th, 2011, 07:23 PM   #9
boggin-machine
boggin-machine's Avatar
one or the other. never both!
Old September 6th, 2011, 07:29 PM   #10
GREASYHANDS
GREASYHANDS's Avatar
This ^^^
The only time I have used both together I when the newer gasket has a small tear on it. A light coat over the tear will seal it
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old September 6th, 2011, 07:40 PM   #11
junk90xj
ALLPRO AUTO
junk90xj's Avatar
lube locker gaskets are reuseable and you dont use rtv with them.
that being said i either use rtv or lube lockers. i never use the crappy paper gasket that come with diff covers or rebuild kits.
http://www.apalansing.com/
Old September 6th, 2011, 07:43 PM   #12
Sandals
Fucking Zen as Shit
Sandals's Avatar
I used a gasket once and it always had a little leak, ever since it's always just been RTV for me. I spread a layer on the cover, let it sit till tacky and bolt it up, never leaked.
I have wanted to track down a reusable rubber gasket, i've heard good things but been lazy and never looked.
Sandals is online now   Reply With Quote
Old September 6th, 2011, 07:47 PM   #13
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
I believe most of the leeks are not related to eather RTV or the gasket. It is the lack of cleaning the surface of all of the old gasket material, removal of the grease and over tightening of the bolts, especially with a gasket.
RTV is best for me.
dougstephvoor is offline   Reply With Quote
Old September 6th, 2011, 10:06 PM   #14
deerebowtie
Unchained
deerebowtie's Avatar
weld it shut, problem solved.
Old September 6th, 2011, 10:15 PM   #15
schanxj
schanxj's Avatar
Paper gasket with a thin coating of wheel bearing grease on both sides so it soaks into the paper. Never leaks and is reusable as long as you are gentle when you replace fluid later.
schanxj is offline   Reply With Quote
Old September 7th, 2011, 12:53 PM   #16
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
this
RIP FULLSIZE4LIFE
Old September 7th, 2011, 01:58 PM   #17
Dylan
Dylan's Avatar
I've done both and never had problems. The dana 35 always leaks at the stupid rubber fill plug though.
Old September 9th, 2011, 11:58 AM   #18
MagMan68Classic
Thanks for all the replies
I think I'm going to try to RTV it ($$)
It sounds like the biggest thing is to make sure the surface is clean.
Any recommendations on technique?
One of my friends told me to use a razor. Its super slow, but super effective
I've also read brake cleaner
Old September 9th, 2011, 01:32 PM   #19
Dylan
Dylan's Avatar
I use brake cleaner with a scotch pad. Just don't use one of those sanding wheel pads on the air grinder. It will sand/polish the surface and the rtv will not stick LOL. Learned by experience lol.
Old September 9th, 2011, 01:51 PM   #20
jaysusr
jaysusr's Avatar
Just jb weld it. All good.
Tags
dana, gasket, rtv
Page generated in 0.34164 seconds with 84 queries
