XJ: Key will not turn in ignition. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 6th, 2011, 02:40 PM   #1
FlatFender
Tap Tap Splat
FlatFender's Avatar
Default Key will not turn in ignition.
Drove my XJ out to get gas last night, everything was fine. Came home, parked, wheels perfectly straight. Get into it this afternoon, put in key, and the key will not turn. I've tried jiggling the shifter, turning the wheel, etc.
I started the jeep with my remote start, thinking I would be able to turn the wheel a little, but that didnt help, just activated the steering wheel lock.
I blew out the cylinder with some penetrant, thinking maybe there was something stuck, but everything appears fine. I also tried another key that is not worn as much as my regular key, no dice.
Steering locked, shifter locked, etc...
Any ideas?
Old September 6th, 2011, 02:46 PM   #2
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Spray some WD40 / other PENETRANT in the cylinder and work the key in and out. Similar thing has happened to me on door locks in the past and this cleared it right up. A locksmith told me as I was inquiring on trying a new cut for the key.
@clarkstoncracker
Old September 6th, 2011, 02:47 PM   #3
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Shit.
Reading is fundamental.
:facepalm:
Sorry
@clarkstoncracker
Old September 6th, 2011, 03:10 PM   #4
bdd1469
bdd
bdd1469's Avatar
If it's 97 or newer,its a common problem.put the key in and smack it with a hammer,like its a nail.dont hit to hard,and hit it square,so it doesnt bend.there is a little piece of plastic in the switch that breaks,and causes the prob. Smackin it is suposed to bust the piece and make it turn.
Old September 6th, 2011, 03:21 PM   #5
FlatFender
Tap Tap Splat
FlatFender's Avatar
Before I read this, I tapped it in with a screwdriver handle, after a couple more minutes of playing with it, it is now working find. I went ahead and pulled the cylinder, I'll replace it just in case it was the issue...
Old September 6th, 2011, 08:38 PM   #6
03tjsport
Red Dragons!
03tjsport's Avatar
I would replace the key too.
03tjsport is offline   Reply With Quote
Old September 6th, 2011, 10:30 PM   #7
FlatFender
Tap Tap Splat
FlatFender's Avatar
New cylinder comes with new key.
Old September 6th, 2011, 10:52 PM   #8
Immortal
NO RELIGION WAT!
Immortal's Avatar
Did you just steal someones jeep?
Old February 17th, 2013, 10:56 AM   #9
BDR
I'll be a son of a bitch, it worked! See kids, this is why you search FIRST
BDR is offline   Reply With Quote
Old February 17th, 2013, 11:37 AM   #10
Gunsworth
Gunsworth's Avatar
That will get you by for a few months, only works for a few times before it needs replacing rebuilding, might wanna take care of it before you get stranded
Old February 17th, 2013, 11:49 AM   #11
DuffMan
Your Message Here
DuffMan's Avatar
Worked on my Dakota two years ago. No issues since.
Old February 17th, 2013, 11:52 AM   #12
FlatFender
Tap Tap Splat
FlatFender's Avatar
This is an old thread. The jeep has since been crushed, and I bought a new car.
Old February 17th, 2013, 11:58 AM   #13
Gunsworth
Gunsworth's Avatar
cool, but we are no longer talking about your jeep anymore, your thread has been taken over. Move along please
Old February 17th, 2013, 12:04 PM   #14
FlatFender
Tap Tap Splat
FlatFender's Avatar
It's my thread bitch!
Old February 18th, 2013, 09:31 PM   #15
BDR
plan to...but this gets me able to move it in and out of the garage to work on it.
Old February 18th, 2013, 10:10 PM   #16
XJcoupe
1ton XJ
XJcoupe's Avatar
thats the best laugh I have had all day - thats Awesome
Old February 19th, 2013, 04:06 AM   #17
bdd1469
bdd
bdd1469's Avatar
Bullshit.
The busted plastic piece falls out, it cant happen again. If you replace the ignition you put that junk plastic piece back in there. Then it will fail again.
Mine failed at 60,000 miles.
I have put 90,000 miles on my jeep without a problem since I fixed it with a hammer.
Old February 21st, 2013, 05:31 PM   #18
Gunsworth
Gunsworth's Avatar
Bullshit.
Well in higher mileage cases, on both my dads and friends jeeps, both around 150k, tapping the.key worked the first and second times, but by the third time, nothing would work and they needed new cylinders. Theres more to wear in the cylinders than a plastic part.
Old February 21st, 2013, 06:02 PM   #19
alterego
alterego's Avatar
plastic gets old and brittle some times in tractor dashbords that causes loss of control of the loader, making snow plowing dificult in temperatures less than 20 degrees unless you plug in the block heater and let it run long enough to warm the neighbors wood pile next to the outdoor log splitter that stopped running because the gas they put in it had water droplets from an unsofted high iron content old style well.
alterego is offline   Reply With Quote
Page generated in 0.38071 seconds with 80 queries
