95 Tub, frame and 6 point cage - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 5th, 2011, 07:01 PM   #1
tynercharlie61
Default 95 Tub, frame and 6 point cage
95 Wrangler tub, frame, and full cage. The cage is made from 1.75” .120 wall DOM and is tied to the frame at all 6 points. The cage also has mounting for the seats that connect to the cage, which are not included. The frame has M.O.R.E off-road bomb proof weld in Chevy motor mounts and the rear of the frame has been narrowed to facilitate mounting coil springs on the outside of the frame for better control. This Jeep only had 18, 000 rust free miles when it was taken apart and has been stored in a garage ever since. The rear of the tub has been dovetailed to give it that competition look and the rear wheel wells were raised 2” so I could run bigger tires with less lift. The welds on the dovetail have only been tacked and are not finished. The grill radiator mounts have been modified to run a radiator in the grill, instead of behind it (not finished). The rear body mounts will need to be modified to secure the body to the frame. Also when I bought the Jeep the guy had welded bumpers on the front and rear that I had cut off so the frame in those locations will need to be dressed up. The cage is one of the better looking cages I’ve seen and was made to accommodate a 6’ 3” driver with more leg room than any jeep I’ve been in. The cage needs to be finished welded. LS1and Dana 60 not included and a factory windsheild frame will not go on due to the cage leg (see picture). Email for pics. tynercharlie@yahoo.com Looking for $1500.00 Make an offer.........
Last edited by tynercharlie61; September 5th, 2011 at 07:05 PM. Reason: forgot to put a price in post
tynercharlie61 is offline   Reply With Quote
Old September 6th, 2011, 08:24 PM   #2
itchy
itchy's Avatar
itchy is offline   Reply With Quote
Page generated in 0.18444 seconds with 29 queries
