NP208F good? bad? what do you know? - Great Lakes 4x4. The largest offroad forum in the Midwest
View Poll Results: what should i do for my Tcase?
keep the NP208F if it is in good shape. 0 0%
rebuild the NP208 if its showing signs of wear. 0 0%
find an NP205 to put in my truck. 1 100.00%
Voters: 1. You may not vote on this poll
Old September 4th, 2011, 07:49 PM   #1
wheelinblazer98
wheelinblazer98's Avatar
Default NP208F good? bad? what do you know?
i just got an NP208F tcase out of a parts truck.
im considering putting it in my 95 powerstroke when i convert it to a 5spd.
a little bit of googleing told me that they typically go out from the shift pads wearing out or from the fluid level dropping too low.
what good/bad experiences have you have with them?
my truck is a crew cab dually and i am considering upping the power a bit on my 7.3L later on, will this case hold up to the power? (it came out of an F350 dump truck)
thanks.
wheelinblazer98 is offline   Reply With Quote
Old October 2nd, 2011, 08:09 PM   #2
wheelinblazer98
anybody? bueller? bueller?
Old October 13th, 2011, 11:17 AM   #3
BOGDOG
BOGDOG's Avatar
I had 3 early 80's Bronco's that used them. The one that saw the most abuse snapped something inside that went thru the case. Other than that I had no issues in over 200,000 miles I put on them. The one that broke had about 150k on it. The other 2 had over 200k when I scrapped the trucks. 2 of the Broncos had 302/4-spds the other was 351/C6 not sure how they will hold up to the diesel torque. They are cheap and easy to swap about 45 minutes with nothing but a wrench or 2 needed.
Old October 13th, 2011, 02:27 PM   #4
wheelinblazer98
hmmmm, ok. maybe i will put it in for now and keep an eye out for a cheap 205 for a spare, after im done with the swap and funds have somewhat recovered.
i think this case has about 160k on it.
thanks for the advise.
Old October 13th, 2011, 02:41 PM   #5
deerebowtie
Unchained
deerebowtie's Avatar
208's aren't bad, they just aren't terribly strong. I've watched 3 or 4 carbed 350/th400/208 combo's snap the 208 housing in mud bogs, flopping it up to the body crossmember on older chevy's. 208's are cheap, thats the good point - you can pick them up for 50-80$ all day long in good working order.
Old October 17th, 2011, 12:29 AM   #6
Never_Evil
Np208 are lighter with a narrow chain, np203 are cast heavy pigs with a thick chain, and the np205 has no chain at all.
If you push something beyond it's limits, you can break the strongest of transfer cases.
Page generated in 0.23367 seconds with 42 queries
