2000 Dodge Ram gearing? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 3rd, 2011, 01:44 PM   #1
Rosco
Rosco's Avatar
Default 2000 Dodge Ram gearing?
I have a 2000 Ram 1500 that i have just put a lift on. It has the 5.2 in it. the truck now has 38" tires on it. now the truck cant get out of its own way. does anyone have suggestions for gearing?
Rosco is offline   Reply With Quote
Old September 3rd, 2011, 03:58 PM   #2
PavementPounder
PavementPounder's Avatar
Having owned a 1997 with the same driveline, I would look at 5.13s with the 318. If you had a 360, you might have been able to get away with 4.88s.
You'll also want to consider swapping in a different set of axles. Don't sink $ into the D44/9.25. Find someone selling a D60/D60 or D60/D70 combo from a 2nd-gen 2500 and swap it in. I believe there are actually a couple sets available in the Marketplace right now.
Old September 3rd, 2011, 04:40 PM   #3
Rosco
Rosco's Avatar
Thanks a lot I am new to all this. but you really just helped me out. My father has a 1999 dually he took apart that has 60s in it.
Old September 3rd, 2011, 04:58 PM   #4
PavementPounder
That will be either a D60/D70 or a D60/D80 combo and wider than what you want.
However, the 1999-up trucks will have the more desirable front brake configuration where you don't need to knock out the studs to get the rotor off.
The 2000.5-up D60 fronts will also be non-CAD. Ideally, that's what you want to target if you have the luxury of being picky.
Old September 3rd, 2011, 06:09 PM   #5
DodgeDude99
your only options for gearing only go up to 4.88's on the 9.25.
i am currently running 37" GY MTR's with 4.88's, and it is about what it was like when it was stock.
the v8 2500 would have a 60 rear, the v10 and diesels have the 70 and 80.
DodgeDude99 is offline   Reply With Quote
Old September 7th, 2011, 03:25 PM   #6
Rosco
Rosco's Avatar
4.88s sound good!! i just need to know where to buy some.
Old September 7th, 2011, 08:12 PM   #7
DodgeDude99
I am not sure who is pushed for vendors on here, but i have always been happy with Randy's Ring & Pinion, with not only prices but also customer service.
www.ring-pinion.com
Old September 10th, 2011, 05:00 PM   #8
Rosco
Rosco's Avatar
Thank you again for all your help..
Old November 16th, 2011, 12:23 PM   #9
BigCountryDRC
Sexual Ninja
BigCountryDRC's Avatar
If You're going to build and keep the truck you'd be better off going with dodge 3/4 ton axles. The swap is pretty easy. They come with 4.10 gears and they're way tougher, so it's a win win. By the time you change front and rear gears you're prolly looking at what a good $600 anyway.
BigCountryDRC is offline   Reply With Quote
Old November 16th, 2011, 07:20 PM   #10
PavementPounder
I agreed with almost everything you said except for this, because it is not true. 4.10s were an option. Don't just assume that's what you're getting.
Old November 20th, 2011, 03:07 PM   #11
BigCountryDRC
Sexual Ninja
Well check the giant tag on the pumpin before you buy it but most of them ive ever seen are 4.10
Old November 20th, 2011, 07:00 PM   #12
snocross2xtremes
snocross2xtremes's Avatar
very un true the 4:10 ones are very hard to find.
also with a 5.2 and 38s 5:13 are the only way to go.
Old November 21st, 2011, 06:10 AM   #13
BigCountryDRC
Sexual Ninja
I know a guy with multiple sets in his garage right now. Start checking door jams if you think theyre so hard to find. Two of my buddys just got 4.10's in there 3/4 tons. I dont know where you guys are looking but theyre everywhere
Old November 21st, 2011, 06:48 AM   #14
PavementPounder
Guess we're looking farther than our buddy's garage.
Nobody is saying they don't exist. They're just not what you should expect to find when they are the option and not the standard.
Old November 21st, 2011, 07:20 AM   #15
BigCountryDRC
Sexual Ninja
All this bs aside I made a phone call and can get you 4.10's or I believe 3.90's for your truck right now. Or D60's but theyll be a little more. PM me for prices might be able to ship the gears or you can pick them up in mt. pleasant. Didnt have to look any further than my budds garage.
Old February 16th, 2012, 12:14 PM   #16
bear jocham
bear jocham's Avatar
If your still looking I have a 60 front and 80 rear out of my 95 2500 v10 with 4.10 gears all complete still under my truck for 900.00 dollars also have 5.5 inch lift for 800 dollars all like new in perfect shape
bear jocham is offline   Reply With Quote
Page generated in 0.53765 seconds with 71 queries
