1995 Bronco rear shackel flip - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 2nd, 2011, 08:38 PM   #1
Thetown555
Thetown555's Avatar
Default 1995 Bronco rear shackel flip
Simply cutting off the old rivets and fliping the rear spring hanger over how many in. does it change the rear?
Thetown555 is offline   Reply With Quote
Old September 3rd, 2011, 09:26 AM   #2
insaneoffroader
insaneoffroader's Avatar
I believe about 3.5".
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Old September 3rd, 2011, 07:31 PM   #3
Thetown555
Thetown555's Avatar
thats more than i thought. thanks for the info
Old September 3rd, 2011, 07:44 PM   #4
masterbeatty
masterbeatty's Avatar
also remember that it moves the rear axle forward about 1 inch i believe maybe 1.5
Old September 3rd, 2011, 07:53 PM   #5
Thetown555
Thetown555's Avatar
as long as the driveshaft fits properly it should be ok correct?
Old September 5th, 2011, 07:43 PM   #6
Lilmuddy
Lilmuddy's Avatar
IIRC the shackle flip nets more then 3.5" of lft. Do a search over on FSB in the SAS section and you will find the answer. The axle does move 1-1.5" forward and most fix it with a zero rate block. Pinion angle rotates up also but everyone that I know that has done results in the pinion pointing directly at the case as needed. As long as the stock shaft is long enough and doesnt slip apart during full suspension flex you should be ok.
Lilmuddy is offline   Reply With Quote
Old September 7th, 2011, 04:58 PM   #7
Thetown555
Thetown555's Avatar
ok thanks guys
Page generated in 0.25280 seconds with 44 queries
